8 members (Nick in Manitou, tclederman, papas52, Robert Crandall, MikeStone1953, Gray_Ghost, Grizzly 34s, 66flea),
65
Mod | | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 64 | Was told by a retired millwright from a sawmill that the best and cheapest penetrating oil is a 50/50 mix of automatic tranny fluid and acetone. I am currently (yeah!!!) fresh out of rusty stuck nuts and bolts, so anyone out there want to give it a try??? And let us know? Ron
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I tried that before, wasn't too impressed. Still have some mixed up. Kroil or Seafoam deep creep seemed to work better for me. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | When I was in the Air Force the guys in the engine shop used hydraulic fluid. I used Kroil on my truck and found it works great. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That was posted here by someone a couple of years ago. I haven't had to add transmission fluid to a car in 40 years but, I just happened to have a quart on the shelf. I probably picked it up for a quarter at a garage sale, so I mixes up a batch and it worked just as good as the expensive brands. Just as good as Kroil, PB Blaster or Liquid Wrench and I still us it. It's just easier to us a pressurized spray for some applications. DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Acetone and about any lite oil works great. Acetone and coleoil works great to unstick stuck pistons. And if you want it to squrit like the other PB's and what have you there are spray cans available for your home brew that you pressurize with compressed air. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I read a post about the mix a couple of years ago. The problem I have with the "mix" is that acetone is extremely volatile and will evaporate quickly leaving only the tranny fluid. I don't see where it would be any more effective than using straight tranny fluid.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | All the old guys around here use wintergreen oil & trans fluid mixed. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....and since we never know just how bad something is stuck we will probably never know what "works the best". I personally like Kroil but I do have PB Blaster, liquid wrench, marvel mystery oil and a few others on the shelf. Seems I "decide" which I use based on how much time I have??? Darn it, now I've got to get some acetone to mix with some tranny fluid. Never know when I might "decide" to try some of it.  ....now wintergreen oil is a new one on me! Maybe it will at least smell better than some of the others? | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | 50/50 diesel fuel and turpentine works pretty good too. I keep it in a gas can because I worry about fumes.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Be careful with the acetone, it is a minor irritant to skin and lungs, and it will soften-up many types of paint (it is a good paint remover).
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I use Kroil.It's the best.Next if it don't work it's the torch' nothing can do the job better
dan-pa
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | On another thread about unsticking a heat riser valve, someone pointed out that the shop manuals suggest using kerosene and baking soda to keep the valve moving. Has anyone tried that?
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I've used baking soda as a medium in the deruster tank with a 12 volt charger with good results. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | PB blaster, Kroil, Knocker loose, WD-40, Liquid wrench, MMO. I have never ever seen any of this stuff actually work. The home brew stuff is probably as good as any.
Weeds | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | But [censored], you haven't told us your secret formula?????
Are ya Gettin' the bugs worked out of that Burb this winter??
Denny Graham Sandwich, IL
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Where could someone find wintergreen oil? Since it's now winter...
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | when i cant get krawl (kroil) to work i use lidquid wrench. mix is 66% oxygen to 33% acetelyne works well but sometimes it loosens up more than what your trying to get loose. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | when i cant get krawl (kroil) to work i use lidquid wrench. mix is 66% oxygen to 33% acetelyne works well but sometimes it loosens up more than what your trying to get loose. That's a good recipe, Mike. I used some of it today. | | |
