| | | Forums66 Topics128,282 Posts1,058,492 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 57 | I have never seen the original jack and lug nut wrench for these trucks. Was the design carried over and if so what years would be compatible with my 1957 3100? Also where can they be found, OEM or reproduction?
Nick 1957 3100 Army Base Runner Cenosillicaphobia
| | | | | Joined: Mar 2010 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 57 | Also, has anyone seen the runner board toolboxes? Same questions...
| | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | Up top on every page of the Stovebolt site... Links, then Parts . For used parts, check the swap meet . -W | | | | | Joined: Mar 2010 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 57 | I realize that. I have had no such luck following the links and no one in swap meet is selling these. From my research I've been led to believe that they aren't making repops of these yet...
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no they're not repro'd and likely never will be, most folks discarded them for a reason  just hafta keep watchin the parts forum and any swap meets you can get to .... put up a parts wanted post and keep bumping it, eventually you'll find one, they do show up ocassionally Bill | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | They show up on Ebay from time to time - and usually they are not cheap - but then--- what is? Dale | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I hope you are not planning on really using one... Check with Filling Station. Sometimes they have some old stuff laying around. Also check with: http://www.cliffsclassicchevrolet.net/Chevy Old car/truck Parts 503.771.9416 Omar Lugo 916.652.0840
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Mar 2010 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 57 | I actually live in Oregon and my commute from the coast to central Oregon puts me right through Lebanon, which is where the Filling Station is based. A great store and I have been in contact with them, they're the ones that told me they're not being reproduced. Thanks for the other stores, I'll give them a call and post in the wanted section. Thanks for the input.
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Nick, Cool about Filling Station...I know JK up there.
Omar..I bet will have an old one for you...
I will check some other places for ya 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Mar 2010 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 57 | Righteous. Is Omar his user name?
