0 members (), 89 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#699604 11/30/2010 3:47 PM
Hey guys,
I don't recall it being mentioned, but I probably missed it if it was, or I'm really behind the times, but......
I was going through a new JC Whitney catalog last night and saw they had one wire 6 volt alternators. They were under $100 too. It seems to me they had 60 and 80 amp. It seems like a good "alternative" change.
Just thought I'd mention it.
Builder
How many amps come out of the original generator?
Dennis
What year and size truck?
He has a 1948 3100 .
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
What's the big love afair with alternators? My 57 has had a generator since I bought it in 1974 and driven 100,000 miles, my Alis Chalmer WD has the generator and 6 volt in the winter I it started in below 0 weather, plow out three drive ways always starts been doing this for 30 years , my 54 Plymouth ,29 Chevy and 30 Chevy truck all the same , now and then I replace the brushes ,BIG DEAL, cost me less than $5!
BILL #699753 12/01/2010 1:31 AM
They are capable of higher amperage output, and are also more efficient at producting power than a similar voltage output generator.
Bill Burmeister
A long time friend of this site Randy Rundle is probably the king of 6 volt alternators . Check out his site Fifth Avenue Garage .
Professional Novice
So. On my 1948 3100 with the 216 engine - how many amps does the 6 volt generator generate? I am sure it is not in the 60-100 range. I guess it is somewhere in the 30 amp range. I am also thinking this is the same if I decided to change over to a 12 volt system. Right?
Thank you
Dennis
yes, 30-35 for the standard 6 volt, maybe 30-45 for later 12V ... one of the reasons for alternators is they can be much higher output
Thanks guys.
I am assuming this is enough output for the normal stuff on a truck.
Is this enough output for all the plain original normal stuff (no radio) plus halogen headlights and air conditioning?
I like halogen headlights and possible LED tail lights.
Thanks again
Dennis
with AC especially, and halogens, I'd think 12V with at least the common 45amp gen would be needed, and an alternator would be best
Thanks for the information. I would also like to change to a pushbutton or key start. Personal preference.
Dennis
I have had an alternator on my 54 for a long time and just lately found out that with the low rear end my engine rpm in most cases was not high enough to kick the alternator on and when it did it would not stay on because of the low rpm. i bought one from jegs that comes on at 800rpm and stays on no matter the rpm unless the key is turned off.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
