0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | not sure what it came from but not advance design.seems like I've seen round faced ones late thirtys. Square might also been available as well. The ones of the thirtys I saw were under dash units, May have been after market.That one looks to be mounted thru a hole in the dash.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would think the radio control head was made to fit in a dash opening. If the chassis has a socket for a vibrator, that will help with the year information. Sometime, I am guessing in the mid thirties, they came out with the vibrator. Before that they used something that was like a motor generator set. Usually on these old radios, you can replace the speaker with a modern day permanent magnet unit. This radio would have used an electro-dynamic speaker. I just finished rebuilding my 1938 Chev radio and it works just fine with a modern speaker.
Ray Holland over on the VCCA site may be able to shed some light on your radio. I can get his Email address if you would like. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just looked through some of my literature and it seems that Chevrolet brought out a radio with a vibrator power supply in 1933/34. I believe that Delco made the radios for Chevrolet. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Jeff: Try posting this in the Electrical Forum, there is a Radio Bench sub-forum there. You might get additional lookers. | | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Delco name in the 40's and 30's, that this radio came from, was used on the "after market" line.The radios called OME's where listed under the make of car or UNITED MOTOR SERVICE the first GM radios where made by Crosley .in the late 30's GM bought out Crosley's auto radio factory ,then Crosley started making Automobiles Motorola and Zenith supplied them with radios! Now I'll tell you that although GM had thier own radio factory building radio in the 1940's, they still bought radios from Colonial Radio, Buffalo NY, The "UNIVERSAL" that many have in their 40-46 trucks is one. This head control looks like it would fit a 37 Buick dash,BILL | | | | | Joined: Aug 2010 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 58 | Thanks for the info guys! Great stuff, as always. I will follow up on the leads.
Jeff | | |
