| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 22 New Guy | | New Guy Joined: Nov 2009 Posts: 22 | I am moving from drum to disc on my 54. I can go IFS and get a new suspension as well as brakes. Cost will be $2,300 or so. Or I can go with a simple conversion kit from performanceonline.com or other for $700 or so. Has anyone worked through this? Any thoughts are welcome. Thanks. Bob | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I used performance online. Very complete,and easy to install. Highly recommend them.(if that counts) | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Obviously the IFS install entails a lot more work. You have the initial purchase cost then,unless you're doing the install yourself you have the added labor costs. Ideally you want to remove the front clip,engine and trans. It just makes access much easier. You then have to consider your steering hook-up (More $$$) If you are just wanting to improve the brakes I would go with the cheaper option. The brakes dont care if its a beam axle or IFS.....
It's what you want that matters.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2009 Posts: 22 New Guy | | New Guy Joined: Nov 2009 Posts: 22 | Thank you. They seem to be the folks to go with. Glad it worked for you. Bob | | | | | Joined: Nov 2009 Posts: 22 New Guy | | New Guy Joined: Nov 2009 Posts: 22 | Thank you. You pretty much detailed all the issues. I am leaning toward the simple brake swap and not the IFS. I can preserve some cash for later issues.
I do appreciate your response. Had a chance to spend 10 days in Scotland a couple of years ago. Beautiful country.
Bob | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
