1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Can anyone recommend a good source for a leaf spring spreader for my 42 3/4 ton? (loaded spring length is 36 inches) I suppose I could just rent one for the job but, my son also needs to use one for his 62 Willys and, I understand they're not that expensive. Maybe someone has one they'd like to sell. Any input will be appreciated. Thanks.
Ghost Rider Little Egg Harbor, NJ 1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5 1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What is it? I don't remember needing anything special for the new leaf springs on my truck.
There has to be a reasonably safe way to do it without going out to buy or rent a tool, leaf springs are pretty simple.
Grigg | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | spring spreader?? got a reference from the shop manual where a Ford tool is useful on a Chevy truck?
Bill | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Spring spreader probably isn't the right term for it, as its normally used to pull a spring into an arc position to install it on some vehicles that have a preload on them. Really doubt that you need to use one though, but in a pinch I've used a come-a-long to pull it together.
| | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Thanks to all for your input on my question. I've only done Model A leaf springs in the past so, I fell back on that experience. Apparently, Chevy leaf springs are not a problem to install in their unloaded state. Thanks again.
