| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Working on a 54. Anyone got a clever idea of how to locate mounting holes in a 54 headliner? I am about to embark on installing a replacement headliner from Jim Carter, and it has no holes in it for the inside visors, and no perforations. Anyone got any clever ideas on how to skin this cat? Obviously don't get any do-overs when cutting cardboard... Thanks in advance!
1956 GMC 100 NAPCO Deluxe 1955.1 Chevy 3600 NAPCO 1954 Chevy 3600 NAPCO
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | grind the heads off the screws leaving a short sharp point. Scrw them in till there is just enough of a point to make a mark.on the headliner. | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 |
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Also,,fill a 5gal. bucket with cusswords. Havent talked to a person yet that hasnt had problems with the repro headliners. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sounds like an old woodworker trick Alvin. I think I still have some of those for transfering dowel holes. Here are a few pics showing that method used on a door panel Blue. Scroll down to the bottom: http://www.pbase.com/dennygraham/ad_interior&page=all DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have used Alvin's technique twice and both times had no problems. No problems with the holes for mounting the interior visors (both sides) - the cut and fit of some of the panels is a different story.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | the cut and fit of some of the panels is a different story. You got that right! headliner pic headliner pic2 That gap was due to the way the liner was die cut, Not any mistake I made... (This time) That is a good tip on transfering the holes. I made a paper template taped to the door opening. I installed the liner by myself, Fun Fun Fun Good Luck | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ohhhhh god, not another pain in the ars to look forward to!!! I just got the head liner for my '54 last month and it's going thru the straightening out process right now. I also have one for that '50 that I'm not ready to install yet. When I laid them both out on top of each other I noticed a big difference in the way they looked. Of course I expected the front to be different, but they dint match up at the back and sides where they should be the same. So here we go again, man this hobby isn't for sissies is it!
This reminds me of the WWII story about the captured Japanese navel vessel that they captured in tact. It was an exact copy of one of ours, right down to the repair patch that the original had on the steam engine. Seems that when they copied the headliners for our trucks, they copied them from an original, right down to the SHRINKAGE! Denny Graham Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I installed the headliner in my '54 long before I found the Stovebolt Page. I didn't dampen the back - as in the tech section - to help fit the compound curves. After a few hours of cussing, I finally said **** it and rough cut it to fit. Has a couple of gaps that I see every time it get into the cab. I'll replace it again, someday.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Lonnie, I've been doing a lot of thinking about this headliner problem, not the cut but the instalation. I'm convinced that the headliner was installed at the factory before the windshield and door surround windlace. It doesn't make any sense to me that they would go thru all the trouble that I've heard about here. If my headliner is shot then I'm sure the windlace and windshield gasket is about due for replacement also. I'm going to replace all three and install the headliner first then the windlace and reinstall the windshield.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
I have never had any significant trouble installing the headliner after installing the windlace and windshield.
I bet you will have an more interesting time installing the headliner first, Denny.
Installing the windlace is very straight-forward as long as preliminary precautions/preparations related to the channel are carried out (these have been discussed here several times).
Installing a windshield and regular rubber seal is not bad, as long as you have a helper.
Installing a windshield rubber and stainless windshield trim is an undertaking I have not yet mastered (but, I have not given up - I have two more trucks/windshields that I will try new techniques on).
