4 members (Southerntruck, Hotrod Lincoln, 52Carl, TUTS 59), 92 guests, and 1 robot.
Topics128,162
Posts1,056,932
Members48,458
#699625 11/30/2010 4:48 PM
Which rearend is everyone using as a swap for a 41-46 trucks or panels? I am adding a IFS with a 350/350 combo and was just wondering what rearend I should be looking for. I will keep it close to stock height and was looking at going 5 lug as the IFS will be 5 lug too. Any help appeciated.
I have a rebuilt '55 Chevy car in mine.
1940 Chevy KC 1/2-Ton
I am using a 2002 4wd Blazer rearend in my '39. Same width as stock and has 5 lug Chevy pattern that matches front disc brake conversion. Plus it is a disc brake rear.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
Mine came out of a 75 Nova 10 bolt 8.5 gear.
69 Camaro fits pretty good.Even the spring pads line up on the same center line witout any mods.
early 70's cougar 9" under my '39.
I used a 1979 Camaro rear end. I got the Z-28 so it was a 3.42:1
Don't use Camaro leaf springs. I used S-10 leaf springs.
But I have to add that my truck is not roadworthy yet and the bed is not on.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
My '37 has a 1979 Trans Am 10 bolt, it had the 3.42 gear but I swapped it out for a 3.08. Width was the same as the '55 axle that was under it, no idea about original axle widths. I swapped the spring pads from the '55 axle since I wanted to use the original 1.75" wide springs.
Joe
I'm putting the rear out of my 69 Olds 442 in my 41. The stock 41 rearend width is within 1/2" of the Olds rearend. I'm not keeping the leaf springs though. 4 bar suspension here.
Dan
I've got a 76 Chevy 1/2 ton rear end under my 39, but it is a few inches too wide... I was able to bolt it in though...
I've got a Camaro rear end that i'd like to put in soon, but i'll need to weld on the spring perchs.
Another quality post.
Real Trucks Rattle
