2 members (Rich'sToys, 1 invisible), 65 guests, and 7 robots.
Topics128,014
Posts1,055,324
Members48,419
#69940 12/13/2006 12:01 AM
Well almost. New for me at least. I have not given up on my 51, 235 that keeps breaking rocker arms. But, I did buy another motor. It is a 60, 235. This series engine was produced from 58-62. Does anyone know if there were any differences in the 235 during those years?
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#69941 12/14/2006 12:03 AM
Riding in the Passing Lane
I havn,t replied cause there is Bolters out there that know more about that than I do. The 58-62 truck engines are pretty much the same. The car engines with powerglide have hydraulic valve lifters. Most cars had the 848 head which gives a little more compression. Somewhere in there the boss on the side of the block for the throttle bell crank was in a different location. I ran into that many years ago.
1972 Chevy c10 Cheyenne Super
#69942 12/18/2006 4:32 AM
Thx wrenchbender,
The boss is there but I haven't measured it yet.
Glenn,
1952 Chevy 1/2-Ton
#69943 12/18/2006 1:44 PM
I recently bought a 1960 235 truck engine to replace my 56. I did a little research at:
http://secondchancegarage.com/public/department35.cfm
Suggestion: select "Chevy engines", click on the year you are checking out, and then scroll WAY down on that page for the specs.
This is a helpful site that gives all the vital engine specs and subtle differences between the various Chevy 6 cylinder engines. It gives specific info on the correct distributor/valve/cam timing which was of special interest.
You'll also need to check into the waterpump adaptor plate/early waterpump, that will allow you to mount your radiator in the proper position on the core support. I hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#69944 12/18/2006 4:20 PM
fla54,
Great site. It sure does help. Thx alot.
Glenn,
1952 Chevy 1/2-Ton
