1 members (baldeagle), 45 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#698918 11/28/2010 12:02 PM
Took my 53 5 window, 216 for her first test drive since the frame off resto yesterday, all went well just a few bugs to work out like my speedometer, the odometer works fine but the speedometer dosen't move. Any ideas?
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #698937 11/28/2010 1:32 PM
The speedo needle turns in bearings and is coupled to the shaft by a cup and magnet. The odometer on the other had is mechanically coupled to the shaft. If the odometer is turning then I would say the grease in the needle bearings has turned to wax and is keeping it from turning. Either take it to a speedo shop or if your feeling adventurous you can open the case and try to free up the bearings.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #699015 11/28/2010 8:02 PM
Ok thanks but the speedo head and cable are new.
1953 5 Window
2006 Chevy Colarado
Charley #699018 11/28/2010 8:08 PM
if the odometer moves the speedo should too, if it's new and doesn't work you should consider discussing it with the vendor you got it from
squeeze #699114 11/29/2010 1:58 AM
Agree Bill.
DG
Denny G
Sandwich, IL
