| | | Forums66 Topics128,010 Posts1,055,308 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Took my 53 5 window, 216 for her first test drive since the frame off resto yesterday, all went well just a few bugs to work out like my speedometer, the odometer works fine but the speedometer dosen't move. Any ideas?
Charlie
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The speedo needle turns in bearings and is coupled to the shaft by a cup and magnet. The odometer on the other had is mechanically coupled to the shaft. If the odometer is turning then I would say the grease in the needle bearings has turned to wax and is keeping it from turning. Either take it to a speedo shop or if your feeling adventurous you can open the case and try to free up the bearings. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Ok thanks but the speedo head and cable are new.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if the odometer moves the speedo should too, if it's new and doesn't work you should consider discussing it with the vendor you got it from
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
