| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I have found what's left of a 47 panel the headlights are intact , i only stoped long enough to take a photo.I plan on going back and get the headlights , how are they attached what will i need to remove them from the fenders. Len
layback
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A phillips head screwdriver to get the outer face ring off....a flat screwdriver to get a couple more small one off the headlight retainer ring... BUT once you get the outside face ring off you may be able to take the entire headlight bucket out!! There is only 3 jor 4 screws holding the entire bucket it. It ain't hard thats for sure.... and always take a pair of pliars with you.
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Sorry i wasn't clear,,I am talking about the complete head light ,and i forgot to mention that it is a 47 first series. Len
layback
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the pods are bolted to the fenders, take a set of box wrenches and sockets, and the screwdrivers too cuz you'll likely have to take the guts out to get at the top side of the bolts
Bill | | |
