7 members (Jon G, ShopRag, Bill Hanlon, Waveski, KEVINSKI, 52Carl, Wrenchman),
70
Mod | | | Forums66 Topics128,262 Posts1,058,331 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I have a 55 2nd series 1/2 ton. This is probably a dumb question but I installed a new model B carb I picked up from carb junkys and attached the choke and throttle cables. The truck has a foot stomp starter and runs fine. I have never used the hand throttle. My question is why did they even put the hand throttle in the trucks? I mean they are fun to tinker with but I don't see any real use for it. Would anyone happen to know the real use in the hand throttle?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | a number of reasons, mostly cuz they were used from way back - and dropped finally after the TF series ... good for holding a fast idle for warmup or using granny gear in the field while you got out and picked up hay bales, useful with a PTO, and some foolishly used it for a "cruise control"
Bill | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | They are usually used to enhance the running when it is first started in cold weather. Also it is a nice feature if you want to keep it charging while it is sitting there running. I had a flooding problem once and the throttle control was really helpful in getting it home without it dying at every stop. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Thanks for the info on the hand throttle. The one I have hooked up keeps popping out a little then in a little when I push the gas pedal is that normal? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you don't have it adusted right or maybe it's not hooked in the right place, should be set up so it doesn't interact with the pedal
Bill | | | | | Joined: Nov 2010 Posts: 19 New Guy | | New Guy Joined: Nov 2010 Posts: 19 | On my 61 it's hooked to the throttle linkage itself. Right at the firewall. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I foolishly use mine for a "cruise control". It works great even though it's foolish!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | From my 82 year old dad who farmed his entire life and had 3100, 3600, and 3800's back when they were new....he used it for all 3 reasons. Helping to keep a cold engine running on start up, PTO drive off the tranny, and yes..the high tech cruise control! He was also a mechanic his entire life on the 'outside world' to supplement the farm income. He has been a huge help in my restoration of my 49' 3600. Helps to have first hand working knowledge! Mine was missing parts and pieces and he remembers where everything goes and can describe in detail what used to be here or there and how it hooked up.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 |
If it ain't broke, fix it till it is
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I recently posted a topic on antique tune-up tools and the hand throttle is mentioned for adjustments at speed since these old trucks had no tachometer. | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | It also helps to take off from a stop going uphill so you can hold the brake and work the clutch and gas at the same time. | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | It also helps to take off from a stop going uphill so you can hold the brake and work the clutch and gas at the same time. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I recently posted a topic on antique tune-up tools and the hand throttle is mentioned for adjustments at speed since these old trucks had no tachometer. that really doesn't make any sense ron | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | It also helps to take off from a stop going uphill so you can hold the brake and work the clutch and gas at the same time. one can alleviate that problem by getting an a/t or learning how to drive with a std trans ron | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Think about it Ron the tune-up specs mention a mph equivalent to test or increased engine speed if you are on your own a way to increase it while testing is to use the hand throttle for a constant increase in engine speed to test conditions under load. Oh and a P.S. I didn't write the directions I just own a copy.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Thinks about it Ron the tune-up specs mention a mph equivalent to test or increased engine speed if you are on your own a way to increase it while testing is to use the hand throttle for a constant increase in engine speed to test conditions under load. Oh and a P.S. I didn't write the directions I just own a copy. it has nothing to do with a tach. throttle may let you set the rpm to a certain position is all that it will do( which was generally done by ea)r. throttle was mainly designed to raise idle after starting, so that you could open the choke aways to maintain it running, so that it wouldn't choke itself out. also to raise rpm for pto drive "is to use the hand throttle for a constant increase in engine speed to test conditions under load". why wouldn't you just use the foot throttle as it would be under load? ron
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | I recently posted a topic on antique tune-up tools and the hand throttle is mentioned for adjustments at speed since these old trucks had no tachometer. that really doesn't make any sense ron It also helps to take off from a stop going uphill so you can hold the brake and work the clutch and gas at the same time. one can alleviate that problem by getting an a/t or learning how to drive with a std trans ron Ron must be having a bad day. Tomorrow he will probably have a better day and not be so negative and judgemental.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | How does one make adjustments alone under the hood using the foot throttle? Extremely long arms?
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | How does one make adjustments alone under the hood using the foot throttle? Extremely long arms? under load means that it is in gear' right. ron | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Also used for hand cranking a cold motor with a low battery or bad eletric starter.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I recently posted a topic on antique tune-up tools and the hand throttle is mentioned for adjustments at speed since these old trucks had no tachometer. that really doesn't make any sense ron It also helps to take off from a stop going uphill so you can hold the brake and work the clutch and gas at the same time. one can alleviate that problem by getting an a/t or learning how to drive with a std trans ron Ron must be having a bad day. Tomorrow he will probably have a better day and not be so negative and judgemental. let's take a look at the first quote if he had said, "I recently posted a topic on antique tune-up tools and the hand throttle is mentioned for adjustments at speed", I would not have said anything. what does "since these trucks had no tachometer" really have to do with the other part of the sentence. second quote. now if you can't drive up a hill from a stop and cannot manipulate the clutch,brake and gas with your feet then one shouldn't be driving unless it is designated for handicap I remember when I took my drivers test, that was one of the requirements to getting your license. now everyone more than likely takes their test in an a/t and eliminates that problem part of coordination. such a permissive society. we do wonder sometimes how people get their licenses cheers ron | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | sorry, I did not mean to start anything with the thread. And thanks for the info. I decided to disconnect the cable from the carb but leave the cable hooked at the dash. | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | Ron obviously has never pulled a boat out of a steep boatramp with a standard transmission truck. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | it is the equivalent of a cruise control/or as was mentioned previously to crank the engine but using the hand crank which as was also previously mentioned would be hard to operate the throttle and crank the engine at the same time... | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Ron obviously has never pulled a boat out of a steep boatramp with a standard transmission truck. is that any different than going up a steep hill with a trailer on and stopping for a stop sign on the way up I have put a lot of mi pulling a tandem trailer behind my 64 for the 20 years that I had it in the mid 70's I also had a HD Hayes with a 5 & 4 pulling logs off highway, so yes , I know how to use a clutch. ron | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Granny gear and 1/3 to 1/2 throttle depending upon how early in the day it was and how fast you wanted to walk loading hay bales. My grandpa had a 63 GMC that he added a hand throttle to. Also had one on a similar model 2 ton grain truck (it was for the dump bed lift though) | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | that 63 should of had one stock ron | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | The invention of the fast idle cam took the place of the hand throttle. But the hand throttle can also be used for many uses.
| | | | | Joined: Aug 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 37 | The hand throttle should not be used as a cruise control as it keeps a constant rpm, not speed, and it does not disengage on its own in an emergency. They are great for cold weather warm-ups, running a pto, and yes most farmers will tell you setting a comfortable speed for feeding with no sidekicks to drive while you throw hay out. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I had a 57 VW years ago and it had a throttle and when we had snow and i got stuck or difficulty getting up a hill i would set the throttle at a walking pace and get out and push to get me out of the situation. looking back not a good idea but it worked at the time. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
