8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd), 97 guests, and 1 robot.
Topics128,049
Posts1,055,702
#698119 11/25/2010 7:02 AM
Members:
I have removed my gauges from the dash..due to them not working. The oil pressure gauge pressure tube was missing. But I found the location of where it is to go. ( rear of the motor close to firewall )..yes ?
But where does the water temp line go ?
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
MLT Offline
On my 51 it is right near the carb on top of the manifolds. I'll see if I can take a pic for you.
MLT #698178 11/25/2010 4:27 PM
MLT Offline
MLT #698183 11/25/2010 4:44 PM
Jimmi - the oil pressure line goes to the drivers side and low on the block. If you have a filter it will share the block outlet for that. Since you have a car engine I don't know where the temp sending unit goes but it will be on the drivers side of the head and can't be mistaken because of the size and pipe threads. I'm sure Tim (tclederman) can supply a photo or service manual detail to clarify.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dear Dave:
Thanks for the info...I have checked the engine # against the form attached and a LAQ is a Truck engine 235 with a powerglide Tranny...even though I have a 4 speed... unless I'm reading it wrong..which is highly likely.
http://chevy.oldcarmanualproject.com/models/engine.htm#53eng
Jimmi V.
MLT #698196 11/25/2010 5:22 PM
Thanks MLT
Jimmi V.
