5 members (TUTS 59, Rusted Nut, dgrinnan, UtahYork, 1 invisible), 342 guests, and 5 robots.
Topics128,162
Posts1,057,057
Members48,463
#6967 04/05/2004 4:26 AM
I see alot of references to the "service manual" from time to time. What kind of manuals are we talking about here. Factory GM manuals, Chilton, Motors or what would you all suggest in buying? And where do you buy them? I really need something for identifing parts.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#6968 04/05/2004 5:09 AM
If they're available, factory manuals are the best. I've got a set of reprint Motor manuals from the early 40's to the mid-60's, (3 volumes), and they're handy, but the factory books are better by far. Some of the more experienced restorers here should be able to suggest good sources for factory reprints.
#6969 04/05/2004 6:34 AM
Anonymous
Unregistered
Anonymous
Unregistered
My most recent manual purchase was a CD from "Detroit Iron USA". I am not that happy with it for what it cost, seems like it was around $50.
I bought it because I needed specs. for a rebuild on a 292 that I am doing and figured I would buy one for 1968 model trucks as I have one of those too.
I had bought a 1968 truck shop manual, but it turned out that I didn't pay enough attention and what I got was the Chassis Rebuild Manual, which didn't have the engine assembly specs. for torquing main caps, flywheel bolts, head bolts, etc.
Get a genuine Chevrolet shop manual for your truck from any of the vendors or from ebay. They are invaluable for figuring things out.
#6970 04/05/2004 6:46 AM
Junior Member
Junior Member
I will have to find you the number, but i called chevrolet and asked for a restoration packet. It came complete with a part distributor booklet and a copy of Chevrolet 1954 specifications. It has all RPO numbers for that year along with every diminsion of th body, frame, and engine. Best of all, They sent it FREE. Mine was originall printer 12-18-53 for the '54 truck.
It has every technical drawing and specification you could ask for...... smile
#6971 04/05/2004 5:10 PM
The best manuals for these trucks are the factory repair manuals. At some point they came up with a factory overhaul manual and took some of the more detailed and less used instructions out of the repair manual to go in the overhaul manual.There is also a factory assembly manual, which was put together with drawings showing the factory where and how to install parts, wiring, brake lines and such.
I have all three manuals for my 69, also have the two available for my 52. Also, for the 69, I have the repair and overhaul manual on CD, it allows me to print the pages I need in the shop, which helps keep the books clean.
If you don't have a local vendor to buy the manuals from, go to one of the vendors in the links sections.
Fred
52 3600
69 C-10
#6972 04/05/2004 11:19 PM
Thanks for all of the info. I guess the hunt is on now.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#6973 04/06/2004 4:59 AM
I have a bunch of manuals I got from ebay but that is kind of hit and miss. Some were good buys and others I had to pay too much.
I have never tried any of those packets from Chevrolet but they sound like the way to go.
The best thing about factory shop manuals is they cover things like the body, windows, doors and etc that other generic manuals don't mention.
Motors Manuals are a big help, but they don't cover a lot of things-they mostly cover engines, trans, generators, axles, brakes and etc. They are a bit better for larger trucks than pickups.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
#6974 04/06/2004 6:27 AM
Call Chevy at 1-800-222-1020, have your VIN number ready and ask for a restoration package, that will include all the specs for your trucks year, and a list of chevy parts suppliers.
I highly advise ordering the Chevy Truck Shop manual for your year, American Classic's has it, so does Chevy Duty. It has been invaluable for me.
I have heard the Factory Assembly manuals are very useful also, just haven't gotten around to ordering one yet.
Frank
