| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69703 12/06/2006 5:45 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | On my 53 the linkage to the peddle from the swing arm on the engine block had the ball at the end that popped into the pedal like on my 55 2nd. Did this truck have that type or was it the other method with the rod that attached to the peddle with a little rod and cotter pin?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
#69704 12/07/2006 3:46 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I just sent a friend a pedal off my 52 that has the little rod/cotter pin. He informed me when he got it that his 53 used the linkage that pops into the pedal. So,maybe they changed in 53??? Heck, maybe it was you I sent it to  | | |
#69705 12/07/2006 2:01 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Good Morning,
Yep, it was me. I was just checking with the folks here on the Bolt to see what they thought and have. Maybe 53 was a mixed year for the linkage hookup. Don't know. But I will either need the type of linkage that your (now mine) peddle uses or a new peddle.
I can send you a check and get your linkage if you still have it. That would answer that question. Thanks again for all your help and parts. You are a great friend.
#69706 12/07/2006 9:01 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | oldblue - my 54 has the one with the little ball that pops into the footpedal - don't know about the 53.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#69707 12/08/2006 5:25 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | oldbluetruck....I have that linkage in a box up in the attic if that is the way you want to go. I can blast it for you and prime it if you like. Just let me know and I will dig it out. Maybe send me an Email. I am going to be real busy this week. We have our car club dinner tomorrow night and Saturday is the last car show for the year....a toy drive for kids etc. Let me know on the pedal....its suppose to be in the mid 20's tonight and saturday with high in the 40's so until I get my propane heat system hooked up I'll wait for warmer days next week to do much!! | | |
#69708 12/18/2006 7:49 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | oldblue - my 53 has the same throttle linkage that has the ball on the end which pops into the gas pedal. The cotter pin and hole are on the other end and are attached to the bell crank which then has the linkage that travels up to the carb.
Whad you do?!?
Shane 1953 Chevrolet 3600
#69709 12/18/2006 10:36 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | |
#69710 12/18/2006 6:23 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Apparently the ball type set up was in use for years. My 37 has the ball that "pops" or snaps into the bottom of the gas pedal. The other end has the 90 degree bend that fits into the bell housing and is secured with a cotter pin. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#69711 12/18/2006 6:48 PM | Joined: Sep 2006 Posts: 29 Junior Member | | Junior Member Joined: Sep 2006 Posts: 29 | My 53 and 57 both have the same setup the peddle pops out of a ball at the end of the linkage.
Those who fail to plan, plan to fail....
