0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Hi:
Just recently purchased one of those brake boost systems kits with dual cylinders from EBay, but there are no installation instructions. It comes with the mount kit and related parts except for two in line vales to maintain the pressure. Has anyone installed one of these and do you have any recommendations on how to best do so. Apparently I have to pull the old arm off the pivot point, how do I keep the clutch pedal on the pivot point in place? Further, how does the brake pedal attach to their system, do I cut the shaft and thread one end to screw into their pedal arm? As to the inline pressure valves, where do they go in the system, at the master, the lines or at the tee block? Any and all suggestions are greatly appreciated. Have a blessed Thanksgiving, we as a nation have much to be thankful to God for.
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | First you need to tell us what truck you are working on and second you need to tell us the kit maker. I have installed them on Task Force Chevies and on ND GMCs from two different manufacturers. There are no generic instructions. | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Cletis:
Thank you and sorry for the oversight. As to the kit maker, it dosn't say. It fits 47-52 Chevy trucks, ours is the 49 model 3100 panel truck. They are seen alot on EBay, and sell for between $168-187.00, does that help? Thanks.
Dave
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Here's what I went through to put the CPP kit on a '54 GMC. It's close to the bottom of the page. Here's what I went through with the Performance Online kit on another '54 GMC. | | |
