3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I was wondering if anyone knew what GM used on the Southern White Pine and steel bed strips. It seemed to be black in color. Is it simply a paint or some kind of coating?
Link to picture
1963 Advertising
1963 C10
I Don't know, but I'm using a standard black semi-gloss on the rails and inner bed sides and tubs.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Tell you what I did: Black rustoleum semi-gloss from a can with a roller on the wood and black semi-gloss from a spray can on the rails. I wanted it to look a factory effort. curt
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
Go to Mar-Ks website, they did testing on quite a few different combinations of stains, clear cote, black, clear, etc. The best results were 3 coats of POR-15 black with 3 coats of Baehr (UV inhibiting black enamel paint) After 3 years all of the clear coats were coming apart but the black combo was still going strong. I just did my pine with Chasis saver satin black 3 coats, and am getting ready to do the UV inhibiting baehr from home depot. Then install with polished Stainless steel hardware and rails. I think it is going to look great and hold up as well. Kieth
ps I bought my wood locally for $56.00, did the dido work myself, saved a lot of money...
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
originally norm before you were born they used pine tar and boiled linseed oil and in later years to black paint
pine tar should be avail at livestock supply dealers
ron
pine tar may have been used early on, but it won't result in the "jet black" finish seen on bedwood - the finish used on the post-war wood was lineseed with "lamp black", the same coloring pigment still used in rubber products
Did they do the same thing for GMC ?
which is basically the same as paint
ron
