2 members (Still At It, wilbur53), 130 guests, and 3 robots.
Topics128,196
Posts1,057,387
Members48,471
#69652 12/06/2006 1:47 AM
I have chance to get some new rear axles for my 54 3100 for $50.00 a pair They are out of a
1953 3100 are they the same..what should I look for in these. Thanks Peter
#69653 12/06/2006 3:07 AM
Petmil, as I understand it that are because I plan to use a 55 1/2 ton rearend in place of my torque tube, in my 52panel, and I'm told the axles are the same. At least for the 1/2 ton. Don't take it on my word yet as I have not actually done it yet. I am sure someone who has will be along shortly.
#69654 12/06/2006 6:01 AM
I used the '53 axles in the '60 pumpkin swapped into the '53 housing.
Unless '54 is a one-year axle, they are the same.
#69655 12/06/2006 6:25 AM
1951-61 1/2 ton are the same.
My Blog
#69656 12/06/2006 4:04 PM
Thank you all
#69657 12/07/2006 3:52 AM
colin, what gear is the 60?? I have a 55 to put in my 52 housing but it is a 3.90. Maybe I should look for a later model..higher gear. I'm going V8.
#69658 12/07/2006 10:40 PM
Achipmunk, as Pre '68 Dave said the axles are the same till '61. I think the ratios were only available for trucks as 3.90 and 4.10.
That said, the '60 rear was a 3.90.
I don't know if the hydramatic eqquiped trucks had a different rear axle/ratio. I'd be interested to learn about that.
If you had an overdrive behind your V8 you could run the 3.90 easily. If not, you can still run it, your gas mileage won't be all that great though.
That said, I would find a completely different differential.
Good Luck.
#69659 12/08/2006 2:07 AM
If you are talking just axel shaft they are same...doc
#69660 12/08/2006 3:27 AM
Auto trucks used 3.38 ratio, that Patrick's reproduces.
My Blog
#69661 12/08/2006 4:50 AM
The hydra-matic trucks (54 to 57) used a 3.90 gear.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#69662 12/08/2006 5:59 AM
Thanks Dave.
#69663 12/08/2006 6:06 PM
Peter check for wear on the hub ends of the shafts which can be caused by either a bearing or a seal. I went through about 10 axle shafts before I found a set that which were not too badly worn. Some have suggested a speedi-sleeve or a sweat weld to build up the groove but it won't work. People today will weld axles but those are not 50 year old ones.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#69664 12/09/2006 7:16 AM
My 52 3100 has a 411 ratio, and the ole engine putting some rpm's at 55mph....seriously
would like to go 373 or so...Any suggestions...
BB
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#69665 12/09/2006 9:33 PM
Riding in the Passing Lane
Bill there are 3.55 gears available for that rear end. Most all the specialty suppliers handle them & the rebuild kit.
1972 Chevy c10 Cheyenne Super
