4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
Working on my '51 chevy truck 1/2 ton with a deluxe heater. The motor for the heater has now been changed to a 12v motor and so has been all the electrical system. I am in the process of installing the switch...here comes the question.
I like the looks of the 6v switch and find the 12 volts switch rather funny looking, can I used the 6 volts switch (if so, how?) instead of using the 12 volts one?
http://d1.scribdassets.com/ScribdVi...1ee0nwga701&page=1&viewMode=list
Part No. 47-03905 for the 6 volts switch I like and Part No. 47-03906 12 volts which I would rather not have to use.
The six volt switch will be heavier duty than the 12 volt one. You will be able to use it no problem.
That is a good catalog, haven't heard of them before. That may be another good parts source for all the fellow stovebolters.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
likely the resistance of the 2 would be different for different voltage and motor current requirements [I=E/R] - if looks are the main consideration try the 6v one and see if it burns out, if so buy the 12v and switch the face plate and knob wink
Is a good place to buy parts from and is only about 30 minutes from my place and they got most everything on stock...can't beat that!
Thanks Bill, I already try switching out the face plates but the mechanism and the connection to the knob are different...worst comes to worst I will end up epoxing the knob and customizing the faceplate to fit. I will try it with the 6 volt switch by itself and see if it won't burn up. Thx
I just installed the 12v one and it sucks. It's a flimsy POS that won't clamp tightly and every vendor sell the same junk.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I bought the new 12v switch.
Never installed it. The backing cracked in pieces while waiting to be installed. Its junk.
New 12v switch pic
If possible use an original.
Good Luck
New 12v switch pic
Wow!!! That's good to know. I am installing my 6volts unit for sure and taking my chances....Those new switches are junk.
Good Luck
