2 members (BC59, Danielbolt),
210
Mod | | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | Its time to change the oil in my "54" stock 235, what is the recomended weight oil and how many quarts does it take (no filter) | | | | | Joined: Sep 2010 Posts: 33 New Guy | | New Guy Joined: Sep 2010 Posts: 33 | Hello mperk,
I too was worried about my first oil change in my '52 2-ton with a 235 (no filter). A friend told me I need to use only detergent oil (expensive and difficult to find). Someone else suggested I use only 50wt non-detergent. I looked around this site and saw several other suggestions. I finally decided to go with Super Tech 10W-30 (Wal-Mart brand) for our upcoming Wisconsin winter and then 10W-40 for summer. It took just less than 5 quarts. I hope this helps. Good luck. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A friend told me I need to use only detergent oil (expensive and difficult to find). Detergent oil is very easy to find, all modern motor oils are detergent, unless marked otherwise.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | He might have said Non-detergent. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...even the non detergent is not "expensive". I see Advance Auto has NON-detergent in Shell, Castrol and I think they have a store brand in ND. If they have it I'm sure the rest of the Flaps have it to. | | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | I'm using the SHELL Rotella diesel oil in my 235 it lines the cylinder walls and doesn't all just run back to the pan. Runs great! | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | When I worked in an oil change shop in high school I remember a lot of guys running rotella and dello diesel engine oils in there antiques. | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | I think Rotella is a good choice for any hard working engine.The additive package needed for a good diesel oil has good acid neutrilizers and most if not all styles still have zddp for protection of our cam lobes and followers this is denoted by NOT finding the words "energy conserving" on the round symbol where the service classification (se,sf,sg,Etc) is found. Most modern automobile engines are built with tighter clearances than our stovebolts and need oil made from thinner basestock to allow proper flow especially during warmup. In multi grade oils,(10-30,5-30,etc)the lower number is the basestock from which the grade is formulated by adding viscosity modifiers that delay thinning as oil temperature rises--so 10-30 and 10-40 would have the same cold flow ability(like sae 10) but the 10-40 would not thin out as much at 210 deg F which is where the upper rating is found. Multi grade oil DOES NOT get thicker at higher temp, it gets thinner but does not get as thin as the straight grade at the same temp. For some good oil info from questions answered take a look at www.bobistheoilguy (not this Bob)
Bob Taylor
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something to bear in mind if you use any of the Deisel grade engine oils, they are very high detergent. On an engine that's been run on regular gas engine grade oils, or one that's never been overhauled, this could cause issues by cleaning out any buildup, especially around seals. Not saying you can't use it, but it's best if you're using it on a fresh engine. Personally, I don't buy the hype on the current grade oil wiping out engines. In every case I've heard, the real problem lies in improper engine assembly, improperly manufactured parts, improperly matched parts (race springs on a street cam), or incorrect break in procedure. On an engine that has already been broken in, it's not as big of an issue, or at least not as much as the snake oil manufacturers would want you to beleive. Personally, I would suggest a quality brand oil, 10W30 or perhaps a straight 30 grade, I personally like Valvoline, in the current SM grade oil.
Bill Burmeister | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | We might need to send this to MYTH BUSTERS ! Use there money and parts . | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | this could cause issues by cleaning out any buildup I agree - if the engine has never been run with detergent oil, there will be considerable sludge in suspension. The first oil change should be sooner than normal to make sure that stuff doesn't go through the pump and bearings too many times, or clog the filter (if you have one). | | |
