2 members (R&S 51 GMC, Tiny),
152
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have a 1939 Packard with a flying lady holding a wheel as a hood ornamnent. She has a piece of glass about 5" long, which look like wings. The glass wing is held on by a pinch fit between her body and head. The head is held on with a long screw running from the ornament base to the head. I want to send the chromed pot metal lady to the platers but can't get the glass wing out of the body as the PO has cemented or glued the wing to the body. The cement seems to be some sort of rubber compound. Any suggestions on how to remove the wing? Thanks in advance.
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | You might have to just keep working the wing until it comes off. Or just soak it in paint stripper, that will reduce the glue or rubber compound. Be sure the wings are glass though, if they are acrylic they will crack and shatter if you soak them in anything that contains alcohol.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have already tried "Kroil, the oil that creeps". No luck. I'm now trying silicone, as it seems to get under and turn loose rubber compounds. I'll try your suggestion next. BTW, it is glass and if you know Packard parts, you don't want to have to buy another. Thanks
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I'm hesitant to suggest this because of the rarity and value of the piece. I have noticed that the carb-dip buckets really does a number on rubber. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | rubber cement uses acetone as a solvent and remover
Bill | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Bill has a good suggestion, try the acetone first before going the paint stripper route, better safe than sorry. Glass adhesive could be etched right into the glass but it should still come off. Maybe if you can get an air fitting into the threaded portion you could use air to help pop it out? | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | If you can't get the ladies wings off, I'll be glad to take the car off your hands !!  | | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | Right church, wrong Pew. Try packardinfo.com. You can be sure that someone on that forum has faced the same problem. No offense to Stovebolt.com but the hood ornaments are a bit different. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | At the end of the day, I clean the 60+ year old grease from under my fingernails. I don't much care what marque it came off of. The love of bringing old tin new life is enough.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Whew!!! It finally let go. The bath of acetone helped big time. I was able to slip a very thin blade between the glass and metal to cut most of the softened glue. Then took a piece of small diameter welding wire, put a chisel tip on it and used it as a drill bit. Glass popped out, no worst for wear. Thanks guys!
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Now we know who's more stubborn, the hood ornament or the owner! Good stuff! | | |
