1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | does anyone know what newer style wheels will fit on my 63 C10, whats the bolt patern, i was just wondering
speak softly and carry the biggest wrench
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The bolt pattern is 6 on 5.5. You'll ned to look at a wheels that fit the '73-'87 full size 1/2 ton 4x4, they will have the correct pattern and backspace.
Bill Burmeister | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | longbox55 i appreciate it, i a 1st timer glad this site is here, so much help and knowledge, thanks
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Indeed newer aluminum wheels such as those found on 4x4 Toyota's have the same bolt pattern as our 60-66 6 lug trucks. Problem is the center hole size is different (bigger) and these style wheels have a lot of backspacing. That doesn't mean they won't bolt up, it's just that depending on what size tires you use you may have some rubbing issues. Are you familiar with the 67-72 chevy truck website? They have a lot of posts in regard to different wheel types on our 60-66 trucks. Check this out: http://67-72chevytrucks.com/vboard/search.php?searchid=1973342&pp=25Hope this helps! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | thnaks hot rod im gonna look into it , gazim i sent you one reguarding the one you sent, thanks guys
