5 members (Jay R, Jon G, Joe H, TUTS 59, 68ironhead), 107 guests, and 2 robots.
Topics128,049
Posts1,055,747
#694623 11/13/2010 8:51 PM
does anyone know what newer style wheels will fit on my 63 C10, whats the bolt patern, i was just wondering
speak softly and carry the biggest wrench
lemon63 #694700 11/14/2010 3:13 AM
The bolt pattern is 6 on 5.5. You'll ned to look at a wheels that fit the '73-'87 full size 1/2 ton 4x4, they will have the correct pattern and backspace.
Bill Burmeister
LONGBOX55 #694801 11/14/2010 3:02 PM
longbox55 i appreciate it, i a 1st timer glad this site is here, so much help and knowledge, thanks
lemon63 #694817 11/14/2010 4:00 PM
Indeed newer aluminum wheels such as those found on 4x4 Toyota's have the same bolt pattern as our 60-66 6 lug trucks.
Problem is the center hole size is different (bigger) and these style wheels have a lot of backspacing.
That doesn't mean they won't bolt up, it's just that depending on what size tires you use you may have some rubbing issues.
Are you familiar with the 67-72 chevy truck website? They have a lot of posts in regard to different wheel types on our 60-66 trucks. Check this out: http://67-72chevytrucks.com/vboard/search.php?searchid=1973342&pp=25
Hope this helps!
Sent you a pm,lemon63
gazim #694826 11/14/2010 4:41 PM
thnaks hot rod im gonna look into it , gazim i sent you one reguarding the one you sent, thanks guys
