7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy),
57
Mod | | | Forums66 Topics128,008 Posts1,055,285 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | Yeah, So being a kid that started his engine training in the age of fuel injection and Crank Sensors, I'm still on the learning curve with this.
When I test out my ign coil resistor I get the full 12.5 volts out of the other side of it. Seems to me the voltage is suposed to be reduced down to around 7 volts from what I read around here....
Someone agree with me, or slap some sense into me.... | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Ohm law says I = E/R. and E = IR. Now then if you have no load connected to resistor then E (voltage drop) is zero. Thus you will have 12 volt - just like you got. Connect a load and see what you get.
Dan Bentler | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | also disconnect one wire and measure the resistance across it, might be shorted out  Bill | | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | ahhhh got it. Begin the slapping. | | |
