6 members (Shardean, TUTS 59, Joe H, Otto Skorzeny, RLB, 1 invisible), 102 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#694641 11/13/2010 11:35 PM
Yeah, So being a kid that started his engine training in the age of fuel injection and Crank Sensors, I'm still on the learning curve with this.
When I test out my ign coil resistor I get the full 12.5 volts out of the other side of it. Seems to me the voltage is suposed to be reduced down to around 7 volts from what I read around here....
Someone agree with me, or slap some sense into me....
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
Ohm law says I = E/R. and E = IR. Now then if you have no load connected to resistor then E (voltage drop) is zero. Thus you will have 12 volt - just like you got. Connect a load and see what you get.
Dan Bentler
also disconnect one wire and measure the resistance across it, might be shorted out wink
ahhhh got it. Begin the slapping.
