2 members (baldeagle, Shardean), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#690319 10/29/2010 11:14 PM
has any one ever used a 79 caprice rear end in a 1953 3100.
johns truck #690508 10/30/2010 5:16 PM
No, but that's one I'm considering for my 55 2nd series. YOu don't by chance have a width on it do you?
Doug5558 #690690 10/31/2010 2:38 PM
yes it is 55 1/4 backing plate to backing plate and has 2.73 gears
johns truck #691136 11/02/2010 2:04 AM
2 Offline
I used a 93 caprice rear end under my 55 cameo. 3.08 posi running a 261 with TBI and T5 transmisson worked great.
28chevys #691279 11/02/2010 4:11 PM
I learned to never measure from backing plate to backing plate. Measure from wheel mounting surface instead. Some rearends have wider brake drums. In your example of a 79 caprice you might find a 2" difference in widths depending on original equipment. Some higher end cars got the bigger brakes. Something to watch for.
gotgasd #694355 11/12/2010 9:32 PM
I know the rearend from an 84 Caprice fits, my 52 has the complete frame from the 84 Caprice under it with frame mods. Worked really well.
