| | | Forums66 Topics128,077 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Lookin for a template or measurements, to put out on the deluxe fender trim for a panel. Thanks in advance Perro
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | How would you suggest one make a accurate template? I have the rear fenders. I know theres a lot of holes to cover. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Did you get my E-mail with pic's? Sent it out yesterday. | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Not sure how to make a template, Just hoping someone had one. I have found some very valuble info here.That i thought was not available or known etc. And no I did not receive an email. Here's my email [email protected]Randy
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I'll resend. I can tell you the trim consist of 3 rows spaced 2 1/4" apart. They are set out on a level plane, the top row is 12 1/2" up from the bottom of the fender @ the wheel well opening.
What I measured is the distance between the row of "holes" hope you got the pics? I still might be able to make you a template.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | You might want to check that spacing again. I just went down and measured mine and theyre 3/4" apart. Thats in between each piece. Theyve been on my truck since day one.1954 If needed, i can send pics to your e-mail. | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I have what appears to have been an NOS fender on the left rear of my 1 ton panel. It has all the holes in it. I could do a rubbing on it so you could lay it out that way. I think they are slightly oblong but I'd have to look to verify.
| | | | | Joined: Jan 2010 Posts: 1 New Guy | | New Guy Joined: Jan 2010 Posts: 1 | I have just scored a set for my burb. I would like dimensions or a template if possible also. Thanks in advance. | | | | | Joined: Dec 2008 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 35 | Wish I could score a set for my burb..booo
