7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny), 102 guests, and 3 robots.
Topics128,071
Posts1,055,901
Members48,429
I've searched and read a bunch and am hoping a few seasoned types will reply with the parts needed for a swap from the 235 whilst keeping the heavy duty three speed transmission (just re-built). I'm looking at less money for a crate 350 than a rebuild of my six, at least in my area. The added hp would be helpful for yanking my boat out of the water at the launch ramp.
Kim
Kim,
I can help you with this, I did the conversion on my 56 about 5 years ago. E-mail me direct. Fred
Riding in the Passing Lane
I,ve done 2 of them lately. Pretty straightforward as the V-8 was an option that year. Get a 55-72 v-8 bellhousing,flywheel, & clutch. You can get the factory front engine mount kit at the specialty suppliers but if you want to change to a later model pulley system for power strg. or a/c you can get a universal crossmember & mount it with the side mounts. Get a v-8 throttle kit from a specialty supplier or adapt a latter model or Locar. I like the Goodwrench crate engine also. Reply if you have anymore questions.
1972 Chevy c10 Cheyenne Super
you'd also hafta use the crossmember [rather than the front mounts] is you use an automatic trans
