8 members (FAST55, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf, 55shaker, Ponchogl), 75 guests, and 4 robots.
Topics128,065
Posts1,055,868
Members48,428
Apprentice
Apprentice
Hi Folks, Just a quick question as I put my '52 GMC back together. The radiator I have is not pressurized, which seems to me like a bad idea. should I modify it to hold pressure and run a 6 lb cap, or leave well enough alone? I am running a stock 270, and live in 100+ degree summers. I have an old Brit car that won't make it to the end of the driveway without a 13lb cap and a big electric fan... Maybe the unpressurized system works fine the way it is? Thanks, Tom
most came with a 3lb I think, and 7lb is about as much as ya wanna stress the ol rad
I would advise the use of a proper pressurized cap or you invite boiling problems.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Ex Hall Monitor
Ex Hall Monitor
You should be OK unpressurized if you don't sit idling for periods of time. It gets over 100 here too & the 38 is unpressurized. The only time it gets uncomfortably warm is at idle. For that fact that's when I get uncomfortably warm too. grin
Tom,
Do you have a shop manual for your engine and/or truck? The GMC radiator and engines are distinctly different from those used in same year Chevrolet trucks.
I think that a 1952 Chevrolet small-truck radiator cap was 0 lbs pressure. In 1954 that changed to 4 lbs pressure in small trucks and 7lbs pressure in automobiles.
If you have a GMC radiator, I think there is a pressure-relief valve on the radiator. Maybe a GMC person can provide information about using a pressure cap on these radiators (maybe someone above was specifically referring to a GMC radiator/engine?).
Tim
I would use a low pressure cap and an overflow catch can, to keep the radiator full.
Just my 2 cents,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I have the GMC radiator, just like the one in the manual. It has the 4 lb relief valve over to the side. The main filler does not have a spill pipe/hole in the neck so no matter what cap you put on, there will be no regulated relief through the main cap. The pressure relief comes from the spring loaded seal at the bottom of the cap assembly and when that opens, there is supposed to be an exit hole above that and below the top of the cap. This hole is missing in the GMC type setup, at least in the manual and on my radiator.
1951 1 Ton Completed
Apprentice
Apprentice
my 52 gmc has been running a 6 lb cap for years and even on the hottest day in the summer the engine temp never gets above 180 cool
What is hottest,83.LOL
Ex Hall Monitor
Ex Hall Monitor
grin grin
