5 members (Bill Hanlon, artinva, Hotrod Lincoln, RoadsScholar, 1 invisible), 98 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#693053 11/08/2010 1:42 PM
The rear hubs on my '53 3100 are leaking gear oil. Would replacing the rear wheel bearing seals solve my problem? Are there any problems I can look forward to when replacing these seals?
eightfan #693056 11/08/2010 2:09 PM
Not as long as you know how to pull the axles.
gazim #693060 11/08/2010 2:17 PM
The Shop Manual seems pretty straight forward as far as removal and replacement of the axles. Are these the only seals that keep the oil where it is supposed to be?
eightfan #693065 11/08/2010 2:28 PM
Pinion seal at the diff, but that no where near the hub!
Bigtonka #693076 11/08/2010 3:01 PM
Scare up an installation tool slightly smaller than the seal O.D. be it a big socket, pc. of pipe etc. It can get bent using a hammer to tap it in and if the bearings are original it’s probably worth changing them while you’re there. Also look for a groove in the axles and if present try to offset the new seals a bit.
You Tube
Curt B. #693090 11/08/2010 3:48 PM
Thanks for the tip on the socket or pipe...Should I change the wheel bearing seals and the pinion seals? How about an online resource for the parts?
eightfan #693098 11/08/2010 4:15 PM
If you have a pinion seal then your truck has been molested as there’s no such thing with a torque tube setup. If the stock rear is there the bearings and seals are available from places like BC Bearing, Kinecor, Commercial Bearing, etc. cheaper than the vendors and here’s the numbers:
Rear axle seals: CRC 18695
Rear axle bearings: National R1502CL
As for an online source, here ya go but they have no stock:
http://www.chevsofthe40s.com/detail/6277/Chevrolet_REAR_AXLE_BEARING_SEAL.html
You Tube
Curt B. #693124 11/08/2010 6:19 PM
Axle seals can be driven in with a piece of wood and a mallet.
Cletis #693130 11/08/2010 6:34 PM
I don't want to waste money on parts that are good...how do I tell if the rear bearings need to be replaced? Thanks
eightfan #693159 11/08/2010 8:00 PM
Look at the bearings for pitting, scuffing or discoloring. Also look at the axle surface that rides against the bearing. Check it for scuffing, grooving. Before you pull the axle out see if the axle is loose, lift it up and down while holding it at the flange end. You can also look close at the seal and see if it cracked or split. Sometimes they get old and hard and it doesn't take much for them to go bad.
Riding in the Passing Lane
I'm with you Eight. If the bearings are good there is no need to replace them. Like
Don say's check them for pit's. If the axles are scored you know the brgs are bad. The seals are easy to get out & in once you pull the axles but the brgs can be tough. If there is grease on the shoe linings they will have to be replaced. There is no way to clean them sucsessfully.
1972 Chevy c10 Cheyenne Super
Napa?? has them at the best price
Reading the shop manual at Rear Axle 4-4, #3 under Axle Shaft Bearing or Oil Seal Removal...what does it mean by "dress out the old stakes points."
eightfan #693399 11/09/2010 2:32 PM
I'm guessing they mean punch marks that stake the bearing in place and hold it from turning.
Any tips on removing the bearings and oil seals? Having a hard time with it.
I am replacing my rear wheel seals since i have my brakes apart. I am paying $56 for rear seals. The parts guy crossed the crc 18695 number with timken 414045. $26.99 each!!! Special order so i wont see them for 4 days.
I also am replacing my front bearing seals while i have everything apart. Timken part number 40973s which are $43.99 each and i dont get them for 4 days also.
If anyone knows of a better priced outlet, I am open to suggestion. Thanks.
