8 members (TUTS 59, wilbur53, Joe H, tclederman, Charles in CA, kades51, 2 invisible),
74
7
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | Just HOW do you find anything in this manual? I tried looking for info on the ig- nition switch,& ended up going thru the whole manual,as it had no index,or easy way to find what I'm looking for. Does anyone else have this problem?
- Doug | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I too find the way the book is laid out illogical (as spock would say).
You would think it would be laid out as to sections or subassemlies. No suck luck. A little past the middle of the book is the known wiring diagrams. Best I can do for ya. | | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | Same problem here. Just plan on doing the finding and reading the night before you want to do the work.
'64 Stepside LWB.
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I believe the basic problem is the contents weren't originally intended to become a book. Having worked at Peterbilt back in the 70's with similar documents, it's my belief the "Assembly Manual" is simply a compilation of individual assembly drawings. These were originally developed to establish best assembly practices or sequence instructions for each entry.
Don't know about GM, but at Peterbilt there was no "book". If you needed something on one of the pages you went to Document Control and had them run a copy. I suppose we should just be thankful the source documents were retained and assembled into a single volume instead of being discarded.
| | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | This is what I did. The very first page of mine has "1953 thru 1959 Vehicle Serial Number Identification" (don't understand that in a 60 to 66 manual but anyway). I numbered that one as page 1. Then I went and numbered every page in the book. The last page I have is 528 (bear in mind it is blank). The last page with data on it is 523 in mine. Then I created an Excel file in which I tried to identify what was on each page. Now when I want to reference the manual I start there. Doesn't always work but it makes for a good start. Of course I have a 64 so I don't have everything listed prior to page 350. If it helps this is what I have found: 1960 starts on page 15 1961 starts on page 203 1962 starts on page 235 1963 starts on page 305 1964 starts on page 350 1965 starts on page 408 1960 starts on page 454 Keep in mind that so much is interchangeable on these trucks that you may find what you are looking for in another section.
| | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | As stated in previous posts, I don't think there ever was a formal "ASSEMBLY MANUAL" per say, it's an assembly of pages of building and assembly instructions, that's all. I'm glad to have one, it's a great idea HOWEVER; you will not find one that is complete (at least not in my experience) holding all instructions. GM publishes different repair instruction in different books, not everything is in the general repair manual, there are transmission manuals, electrical and frame manuals and so forth. When lacking factory instructions I have found it best to post my questions here or other forums, or look at a good installation on another vehicle....
1999 GMC Yukon 1957 GMC 100 Panel
| | | | | Joined: Feb 2002 Posts: 2,895 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,895 | As I understand it, the 'factory assembly manual' for the 60-66 trucks... was initially put together by an aftermarket supplier.
So, there is no index and it makes no sense.
I use post it notes to mark things.
-W | | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | I have the same problem,thought i got a bad manual or something, glad I have it though. Once you find what you're looking for it makes things easier. | | |
