| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I had a local metal shop bend two pieces of 14 ga. steel to my specs. The two u-shaped pieces made the top and bottom. I put baffles in and welded in bungs for inlet tube, fuel pick-up, drain and vent tubes. Then I welded it all together. I need to pressure test it for leaks still. It is 28.5" X 20" X 14" making it about 32 gallons I think. I was wondering if anyone knows why factory tanks (on new trucks) have a vent line from the tank to the filler neck. What is its purpose and do I need to add that or will the vents on the tank "box" suffice? Thanks! I'm trying to add some pictures too: http://s605.photobucket.com/albums/tt138/capedcat/fuel%20tank/[/url] Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy chevoldsmoyota, I believe the vent line is there to allow air to escape from the tank while you are filling it with fuel. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I was wondering if anyone knows why factory tanks (on new trucks) have a vent line from the tank to the filler neck. What is its purpose and do I need to add that or will the vents on the tank "box" suffice? Thanks! Your vent should be fine .Does it have a rollover check valve ?The vent to the filler is to allow the fuel to go in as fast as possible .If this vent is clogged or pinch it takes a long time to fill your tank.Here is a good link with pictures of a tank build .Yours is looking good and it's huge ! Why so BIG ? http://www.streetrodderweb.com/tech/0909sr_building_a_custom_gas_tank/index.html | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Thanks for the link! I wish I had read that before I "reinvented the wheel" so to speak. But it was a fun mental excersize and fun to weld up.
I made it big because I'm wanting this truck to be my "everything truck" by which I mean I will drive it every day, and hopefully it will get good enough mileage to go on long trips with. I am planning to (and this will make a few of you smirk, I'm sure) put a tee in the fuel line with a flexible hose for filling up lawn mowers or stranded motorists. I saw it once on a police cruiser and thought it was cool.
On Dad's '49 we used a Jeep Cherokee tank and it fit very nicely. His is a 3/4 ton. Mine is a full ton chassis and the same tank would not fit! I didn't know there was that much difference in frames!
Of course there are some down sides. That much fuel will add a lot of weight and cost a lot of $$$! But then, so does this hobby!
Craig
CK
