0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#692954 11/08/2010 2:20 AM
I had a local metal shop bend two pieces of 14 ga. steel to my specs. The two u-shaped pieces made the top and bottom. I put baffles in and welded in bungs for inlet tube, fuel pick-up, drain and vent tubes. Then I welded it all together. I need to pressure test it for leaks still. It is 28.5" X 20" X 14" making it about 32 gallons I think.
I was wondering if anyone knows why factory tanks (on new trucks) have a vent line from the tank to the filler neck. What is its purpose and do I need to add that or will the vents on the tank "box" suffice? Thanks!
I'm trying to add some pictures too:
http://s605.photobucket.com/albums/tt138/capedcat/fuel%20tank/[/url]
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
3B Offline
Hy chevoldsmoyota, I believe the vent line is there to allow air to escape from the tank while you are filling it with fuel.
Your vent should be fine .Does it have a rollover check valve ?The vent to the filler is to allow the fuel to go in as fast as possible .If this vent is clogged or pinch it takes a long time to fill your tank.Here is a good link with pictures of a tank build .Yours is looking good and it's huge ! Why so BIG ?
http://www.streetrodderweb.com/tech/0909sr_building_a_custom_gas_tank/index.html
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Thanks for the link! I wish I had read that before I "reinvented the wheel" so to speak. But it was a fun mental excersize and fun to weld up.
I made it big because I'm wanting this truck to be my "everything truck" by which I mean I will drive it every day, and hopefully it will get good enough mileage to go on long trips with. I am planning to (and this will make a few of you smirk, I'm sure) put a tee in the fuel line with a flexible hose for filling up lawn mowers or stranded motorists. I saw it once on a police cruiser and thought it was cool.
On Dad's '49 we used a Jeep Cherokee tank and it fit very nicely. His is a 3/4 ton. Mine is a full ton chassis and the same tank would not fit! I didn't know there was that much difference in frames!
Of course there are some down sides. That much fuel will add a lot of weight and cost a lot of $$$! But then, so does this hobby!
Craig
CK
