2 members (Charles in CA, Otto Skorzeny), 310 guests, and 7 robots.
Topics128,078
Posts1,056,031
Members48,433
#692248 11/05/2010 1:36 PM
i'm putting on a chrome diff cover on my '59 Apache and was looking for advice to making sure i have no leaks. Any wisdom or advice out there?
Don't put any oil back in. eeeek
Many times I have just used a good silicone after cleaning the housing and cover real good. I like to wait until the silicone has set up a bit before putting oil back in.
After you remove the original cover just make sure the carrier surface is clean for your new gasket.
Drew
If you insist on using a paper gasket, coat both sides with Hylomar or ultra black. Or just use 100% Ultra black. If you do, let it sit over night before you put oil in.
Craig
Craig,
Is Ultra Black a silicone sealer? Seems like a better idea than a gasket.
Drew
You don't have to goop a lot of silicone either. If you use a gasket, I rub it with the silicone with my fingers to get a light coat on the whole gasket. Then I do the same with both gasket surfaces. Remember that however much silicone squishes out, when you tighten it down, the same amount will squish in. The excess is waste and has potential to break off inside. Not so bad in a rear end, but when you have those habits and use it on an engine, you could be looking for plugged oil passages and engine failure.
don't throw away your old cover, clean it up and paint it and save it to put back in a couple months when the chrome crap er I mean cap starts leaking.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
he he he Vern....not exactly the answer i was lookin' fer but an old guy has to be funny sometime!
Originally Posted by DrewP
Craig,
Yes It is Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker. Infact I just used it instead of a gasket between the differential and rear axle housing a couple weeks ago.
Then earlier this week, the small side plate plate (driver's side) of my newly rebuilt sm420 tranny was leaking a little so I dumped the oil removed the paper gasket, cleaned it and thinly coated it (both sides) and reinstalled it. No leaky!!!!!!
Craig
I put a chrome cover on about 2000 miles ago. A buddy of mine recommended this;
http://img.photobucket.com/albums/v228/Avette4me/Temporary/DSC00102.jpg
Permatex high tack gasket sealant. It’s kind of messy but with a shot of carb cleaner when you’re done cleans it up nicely. It's held up well with no leaks.
For what it’s worth, I bought my cover from Patricks. It’s likely foreign, but is decently heavy and has been good so far - as I said, no leaks.
