0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69169 11/26/2006 3:31 AM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | This will be long. My 1 ton panel (Ruby) is now powered by a 261 bored .080, 848 rebuilt head, HEI,T5, 4.10 rear. When I put the 261 in, 18,000 miles ago, I knew there were some problems, namely cyl. #4,5,6 were badly scored but not knowing better I just re- ringed along with bearings and ran it. Rear 3 cyls. burned oil some so I used plug extenders on them and that helped. Compression at that time was (from cyl 1 to 6) 115, 112,115 105,100,98. Now the last three are 102,95,96. Not good; hard to time and set the valves. I have a good rebuilt 235, .040 as a spare. (My wife has wondered why would anyone have a SPARE engine?) Anyway, this engine was in a local Vol. FD truck that rolled. Supposed to have about a 1000 miles on it. No cyl. ridges, hyd. lifters; looks fresh. (Has a funky external oil line from the block to the head). I haven't checked the compression on this engine but assuming it is good, Would it make more sense to swap in the 235 for the 261 or try to do something to fix(?) the 261. Would there be much difference in driving feel between a sick 261 and a healthy 235? I guess that is my question. | | |
#69170 11/26/2006 3:39 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Blacksmithdon,
My two cents. I think the best bet would be on the 261. BUT, this would be dependent on the cylinders cleaning up. I don't think they usually sleeve one of these engines, so if the bad cylinders wouldn't clean up without a life threatening overbore, you might have a boat anchor and the decision would be moot.
Would a donor 261 block be a reality? The condition of the existing scored block would make the decision for you. Good luck
Stuart | | |
#69171 11/26/2006 4:19 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I say be patient and find a new 261 block if you have to. I'm going the other way. I will soon be swapping my perfectly fine 235 for a 261 stroker. I'm doing it because I want the truck to be all it can be and still "look" stock with period accessories and speed parts. | | |
#69172 11/26/2006 5:19 AM | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | "I don't think they usually sleeve one of these engines, so if the bad cylinders wouldn't clean up without a life threatening overbore, you might have a boat anchor and the decision would be moot." From what i read it is already life threatening overbored , unless the .080 is a typo. | | |
#69173 11/26/2006 5:22 AM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | .080 is right. I'm really wondering if there will be that much difference between a sick 261 and "fresh" 235. | | |
#69174 11/26/2006 5:34 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | '52motorhead,
I evidently didn't read the post well enough. I agree with you. If it is already .080 over and now has scored cylinders, it sounds terminal.
Blacksmithdon,
I don't think your question has an true answer...sort of like the apples and oranges deal. If one were to tell you there would be little difference, would you leave the 261 in?
There is probably a 'right' answer, but it isn't in the comparison between a worn out engine and a engine of unknown condition.
Stuart | | |
#69175 11/28/2006 10:52 PM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | 080.is a substancal overbore for shur,some are only good for 030. at best. But some will go 125. without trouble. With this much of an overbore you must also consitter what is happening to the compresion ratio. If the new pistons don't have added chamer volume built in the added displacement could send the C/R through the roof. | | |
#69176 11/29/2006 12:22 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I thought compression ratio was the difference between the cylinder volume at BDC and TDC, or something along those lines. I wasn't under the impression changing the bore size would change compression ratio.
Stuart | | |
#69177 11/29/2006 12:52 AM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Don't throw the 261 in the lake just yet. Here's a thread where sleeves were found locally. Good luck.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=002072#000003
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#69178 11/29/2006 1:13 AM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Awh yes atomarc you are 100% right. when you bore the cylinder it's volume gets bigger at BDC but not so mutch at TDC. Most overbore pistons will compensate for this by sitting a little lower in the bore increasing the chamber size. But they don't always do thi so the mech. will have to. | | |
#69179 11/30/2006 1:39 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | a 261 can be bored .125 without any trouble... | | |
#69180 11/30/2006 4:32 AM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Hey Darin how big dose a .125 overbore make a 261 A .125 over 454 is 482 ci. | | |
