1 members (JW51),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | I have a 1943 Chevy Fire Truck. It is a 6 volt system? I have been restoring this truck and just got it running but I couldnt get the headlights to work with the new 6v battery. I removed the headlights and they say 8v on the back of them. I dont know if the orignal owner replaced the old 6v lights with these and ran it from a 8v battery. My question is, Will a 6v run the 8v lights at all? I figured it might but just be a bit dimmer? Any help would be great! Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes a 43 would be 6v - if the lights are actually 8v rated, 6v would still light them, just dimmer, sounds like you have a wiring problem or a bad switch
Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Nothing wrong with the dimmer logic. Test the bulbs with an ohm meter to make sure they aren't burned out. | | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | When I first got the truck it had a 12v battery hooked up in the truck. I knew right away it was a 6v system so I bought a new 6v battery. I'm not sure if someone had tried to crank it before I got it with the 12v battery and did some damage or not? It wouldnt have cranked because of other issues that have since been resolved but before I took out the 12v battery I did turn the lights on and they worked fine but were bright. I never turned the truck over with that battery. It has only been cranked with the 6v and now runs fine but the lights dont work? Thanks for the help | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | sounds like you burned out the 8v lights with 12v  12v would work fine for turning the starter, although running would require a 12v coil - 6v gauges and lights would suffer - I'd say get new 6v bulbs and make sure the gauges all still work Bill | | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | maybe, all the gauges still work fine. The truck was never even turned over or cranked with the 12v battery? I guess that might have saved the gauges from damage maybe? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, if the truck wasn't run on 12V the gauges would likely be fine, sounds like you got a live one, everybody would love to see some pics with a post in the SVFD or DITY forum  Bill | | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | Thanks bill for all the help! Would love to post pics but I'm new to the forums so I dont know where to find where to post pics. Maybe you can fill me in.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | read about it here, just have to have the pics hosted someplace then put lin ks to them in one of the forums Bill | | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | All light and gauges work fine now, just needed a few inline fuse replacements and changing out. | | | | | Joined: May 2013 Posts: 1 Moderated | | Moderated Joined: May 2013 Posts: 1 | chasenfire hi would like to know more about your truck , i just bought a 1943 chevy buffalo fire truck , it`s been shipped over to the uk now
jonny | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Welcome to the 'bolt Jonny. You'll likely get a better response by sending him a PM or email. He hasn't posted on the 'bolt in almost two years.
