1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Anybody ever created a big bolt pickup with a fleetside (or step-side) bed? I came across this picture somewhere (can't remember where, now) and was just floored. One of the coolest old trucks I've seen. Do you think the bed would just bolt right on with minimal issues? http://img253.imageshack.us/img253/3777/1966c50pickup.jpg | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | As Tim Allen would say Whoa-Ho-Ho-Ho. That's a manly truck for manly men. As for bolting the bed to the frame, I would guess that you might have to do a little fabricating and welding but it should not be a huge problem. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Was there any one ton factory pickups built, something tells me I've seen one. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Not sure, but I assume there was. I think the site I found this one on had a little writeup about it and indicated that it was a 1.5 or 2 ton truck to which they attached the fleetside bed from another truck. I'm amazed at how well it fit. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | That's the one I well remember too. It's a pretty cool and pretty creative set-up. He took off the Running Boards too to make it look even.
BTW, they did make 1-Ton Pick-ups. They were C-30's and actually had a 9 Ft Bed.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 |
Professional Novice
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | It seems I saw one at the 98 ATHS show in Phoenix Az. | | |
