0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Looking for info and specs on the ad suburban???? I recently picked up a 1949 chevrolet suburban its my first and i have alot of ?'s. On weather this and that is stock and or not stock. I figured if I had a resouce or link to the factory specs i could keep referncing it instead of asking a million ?'s, like are all suburban's saposed to have the drivers side cowl vents? mine doesnt, the slot on iside is there but no handle, do you was it removed by someone?? Is the gas tank just below the half way mark on the front side of the tank saposed to have a l Ine going into it?? I have pics for reference if needed?? Thanks bigtony55 EDITED PER K10 REQUEST DUE TO MY SUCH POOR LACK UP PUNCTUATION LEFT HIM VERY CONFUSED
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Tony, I'm going to be a bit a pain in your butt here. This place can be an incredible resource, BUT, you will get the most information when you "Speak" in clear legible sentences, use punctuation and take the time to formulate a question that can be answered. This format is tough enough when people CAN make out what you are trying to say. Try not to make it even harder. Your first question relates to the more common pickups as well. You might look into the gallery pages for your year and see if indeed a '49 Chevy pickup has the driver's side cowl vent. (It does by the way). Later years did away with the vent. As for the next question, someone with more mystical powers will have to summon up an answer for you, because I don't have a friggin clue as to what your asking.:) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Big Tony, its always helpful if you can post a pic. Not sure if you are aware of the online manuals yet but they are good info as well. The link is http://chevy.oldcarmanualproject.com/another very helpful tool for me was/is the assembly manual. It shows a lot of stuff and is a good buy at 20-$25. Money well spent. congrats on finding your suburban. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Tony, I'm going to be a bit a pain in your butt here. This place can be an incredible resource, BUT, you will get the most information when you "Speak" in clear legible sentences, use punctuation and take the time to formulate a question that can be answered. This format is tough enough when people CAN make out what you are trying to say. Try not to make it even harder. Your first question relates to the more common pickups as well. You might look into the gallery pages for your year and see if indeed a '49 Chevy pickup has the driver's side cowl vent. (It does by the way). Later years did away with the vent. As for the next question, someone with more mystical powers will have to summon up an answer for you, because I don't have a friggin clue as to what your asking.:) EDITED my stuff for you and i know the vent was deleted on later year trucks. My ? was did all 1949 suburbans have them? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | THIS might help you identify some of the questions/issues you have Check out TIM'S site for more info. Use the SEARCH feature to answer the many questions/issues that may have, many have already been answered. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The after-market replacement cowl panels are not made with a vent. It is possible your cowl has been replaced. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | The after-market replacement cowl panels are not made with a vent. It is possible your cowl has been replaced. Ok thanks, i figured it might have got shaved off at some point and time thats why i was wondering if it was saposed to be on he 1949 suburbans or not? and does anyone else have this hose coming out of their gas tank? if so is it correct and or does anybody know whats its for? i saw a used gas tank on ebay that guys said his had it too?? gas tank pic http://i89.photobucket.com/albums/k237/bigtony55/IMAG0169.jpg | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | When it came from the factory,it had a steel line from the tank to the fuel pump.You can buy them from the vendors,or make your own.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | When it came from the factory,it had a steel line from the tank to the fuel pump.You can buy them from the vendors,or make your own.
Tim So the tank fed out the side like in the pic? from the factory? | | | | | Joined: Sep 2010 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 42 | I have the same thing on mine | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | my observation based on my 52 1/2ton panel.... where the rubber hose is the picture is where the original steel line attached to the tank. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/shacklebolt003.jpgHere is what I did. Buy a ROLL of steel line. I used 3/8 but it was originally smaller. I unrolled it the length I wanted plus a little extra. Flared one end and slide it up the chassis rail and attached it to the fuel pump. Next I put a fitting into the tank that I could slide a small SHORT piece of hose on. After sliding the SHORT piece of hose on I then attached a filter to the short rubber hose, then another Short piece of hose from filter to the main line. The line is all one piece except where the filter is and if ever a problem the filter is easy to change. It looks really neat and should last a lifetime and the short rubber hose should also last longer than we do. Hope this helps. oh, I got my coil of line at Carquest. I think it was 25ft and cost $26. You'll have a little left for another project. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Here is a photo of the original fuel tank and line that was on my suburban. fuel tank and line jim carter fuel lines Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Thanks for the pics and the info guys helps me out alot i was scratching my head quite a bit looking at that line mid tank LOL | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | There is a pick up tube on the inside of the tank,runs to the bottom.
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | There is a pick up tube on the inside of the tank,runs to the bottom.
Tim That makes sense now i figured it fed thru the top like most newer cars and trucks did this is my first ad suburban i had some ad truck before but they where all projects and never saw the road while i owned them | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1954 A-D Suburban (and all 1954/55-1st series panel body trucks) had a different fuel tank - the pick-up tube and the sender was single assembly that went through one hole in the top of the tank (like the "newer cars and trucks" that bigtony55 refers to).
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | The after-market replacement cowl panels are not made with a vent. It is possible your cowl has been replaced. Im leaning toward the cowl being replaced like you said, I stuck a flashlight into the slot where the handle would be, and I dont see any seam where the old vent would have been and its all flat black in there like most other repop metal i have seen is. | | | | | Joined: Nov 2009 Posts: 15 New Guy | | New Guy Joined: Nov 2009 Posts: 15 | Like bowtietim said, that is your gas line. Probably couldn't get it apart so they cut it in two and slipped the rubber hose on to put it back together.
PRETENDING IT'S BROKEN SO I CAN PLAY IN THE GARAGE.
