Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
11 members (2-Ton, wvstovebolt, MTD91, Gdads51, Otto Skorzeny, TexasJim50, RaNfLaS, TexasFarmTruck, dt235sd, 2 invisible), 101 guests, and 3 robots.
Topics128,290
Posts1,058,554
Members48,491
hello,
I'm a newbie here and thought that I could gleen some wisdom from all of you. I also have a question, or two...
I have a '54 Chevy 1/2 ton pick up that I want to swap a '67 vintage 250 six into.
The 250 was originally a powerglide motor, but I wish to run my S-10 5 speed behind it.
I got an early V8 bellhousing that has the mounting tabs on the sides and the removed the lower part of the starter mounts in order for the bellhousing to bolt up to the 250 with the 250's original starter in place. Then I obtained a flywhell (of unknown origin, I think it's a SBC). the Flywhell measures approx. 14 1/4" in diameter but my 250 flex plate measures 12 7/8". So now the flywhell hits the starter on the 250. Also, the bellhousing is 1/2" shallower than the original 235's bellhousing and I'm thinking that this will be a problem for my already modified 5 speed.
Do you have ideas of what I need to get to make thing swap work as far as the right flywheel and bellhousing?
I have already built a front motor mount to meet the original front mount for the 235. I know I will run into more fabrication when it comes to throttle linkage, too.
Any help would be appreciated.
thanks,
r
Every once in a while, life gets a little more surreal.
How'd you build the front motor mount? I'm planning to just use an aftermarket V8 mount crossmember to put my 250 in my '54 GMC.
1954 GMC De Luxe COE
Quote
On the flywheel/flexplate thing, there are 2 different sizes...you seem to have found that out. The smaller one is a 153 tooth, and the larger is a 168. It depends what you want keep as far as which flywheel you use. If you already have a 12" (I think) clutch, then you'll need to use the 168 tooth f/w and replace the starter. If you still need to get a clutch and want to go with the smaller f/w, you'll be able to use the old starter.
On the starters, they are distinguished by the pattern of the bolts that fasten to the block. I can never remember which is which, tho. Straight across for the 168 tooth and diagonal for the 153 or the other way around. In either case, if you're gonna swap starters, make sure your block is drilled for both types of bolt patterns. (3 holes) If not, that will probably decide which one you go with, unless you buy an expensive mini-starter.
I hope that made sense. I went thru the same thing when I put a 355 and Saginaw 4-speed into my 63 Nova. I had a 168 tooth f/w, a large clutch and had to search for a starter to fit. Then I had to change to a Chevy II bellhousing to get the clutch arm at the proper angle and ended up with a 153 tooth f/w and a smaller (10"?) clutch. Ohh..and a different starter. Since I got all the parts to play nicely together, it's worked fine....exept for that broken Z-bar.
Don't some of the new gear drive or High torque starters have both sets of holes in them? For the 153 use the inner set and for the 168 slide it out to the others. It might solve your problem plus you get a new light weight starter too. Joe
Thaks.
That's most of the information I was hoping to receive.
I'll go check the block to see if it's drilled for both. I guess that will determine which way I go with this.
r
Oh, and I built a mount on the front of the engine that accepts the original front mount for the '54. It bolts into the block right under the alternator on the driver's side and under a tab on the passenger side.
r
Quote
Yes, they do. That's what I meant by "expensive mini-starter." As I understand it, some of them are drilled for both patterns.
