0 members (), 79 guests, and 4 robots.
Topics128,021
Posts1,055,373
Members48,420
#688247 10/22/2010 2:37 AM
Was a back-up light available for the A.D. trucks? If so, how common were they? Can someone share info. on how it worked/was wired, fastened in the rear, etc.? Thanks.
fonz8261 #689054 10/25/2010 1:24 PM
They didn't come with turn signals, good luck on finding a back up light.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
glasman #689062 10/25/2010 1:52 PM
Fonz,
There are several good discussions on backup lights and switches for AD trucks on this forum. Use the search option with "+backup +light" or "+backup +switch" (without the double quotes). You will find several different ideas.
Good Luck,
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #689135 10/25/2010 8:55 PM
Does anyone have original/optional/accessory back-up lights for 55-59 light trucks? If so, would you please post photos of originals, or post part numbers for reproduction units?
tclederman #689157 10/25/2010 11:00 PM
I have an NOS still in the box back up light kit for a 55-59 Chevy truck , I believe the the back up lamps were the save, except for the 6volt bulbs, as a 51-52 Chevy passenger
BILL #689164 10/25/2010 11:20 PM
I've searched the Forums here and just want to be period correct and maintain some originality...I'm considering mounting a Guide B-31 (need to purchase) on rear fender bracket and using a reverse-arm tranny mounted switch (if I can find one) as described in Jim Carter forum. Is this period correct/proper for a '48 Chevy 1/2 ton p.u. 4 speed floor shift?
fonz8261 #689201 10/26/2010 1:38 AM
Here's mine. Mine were NOS, still have the box, dated 1955. The part number is 987225. It is correct that the bezel, gasket, and lens are the same as the '51-'52 Passenger, as well as the '51-'53 Pontiac, the base and rubber mounting pad are truck specific. To my knowledge, no one is reproducing the base or the mount pad, but the lens, gasket, and bezel are available.
Bill Burmeister
LONGBOX55 #689209 10/26/2010 1:50 AM
The type of back-up lamp I am looking at is mounted on a bracket, which in turn is mounted on the rear fender bracket. I see this as a neat little accessory to add, but I want to make sure it maintains some authenticity. They are showing up on eBay now and again, minus the switch. Any help with this project is appreciated; it is all a learning experience for me! Thanks.
fonz8261 #689584 10/27/2010 2:40 PM
I bought the kit off ebay many years ago. I installed it on the 55 2nd. That truck had the column shift. The back up lights were the same as on the early 50s cars. I made some brackets and installed them just above the rear lights. It worked well.
This kit also had the set up for a 4 speed floor shift transmission. I have purchased the plunger for this set up and plan to have back up lights on my 48. I will make the same brackets and install backup lights from an early 50s car. This truck will probably stay 6 volt. The 55 2nd was 12 volt.
I hope this helps
Dennis
Here's some pics of when I installed a switch and lights on my green turd.
back up lights
Craig
fonz8261 #689975 10/28/2010 9:28 PM
Yes they were available, no they are not an official accessory. The most commonly used one is a Guide model B31 mounted on a clamping bracket. The 55-59 units came with two different switch mounts. one for column shift units and one for floor shift units. You could use a dash mount toggle or plunge switch to actuate it too.
1956 GMC 100 NAPCO Deluxe
1955.1 Chevy 3600 NAPCO
1954 Chevy 3600 NAPCO
#690279 10/29/2010 8:48 PM
Finding a good 4-speed (floor) tranny switch appears to be the biggest challenge. Any help on how this was mounted/wired would be appreciated. Thanks.
fonz8261 #690587 10/31/2010 1:35 AM
Go back to my earlier reply.
Craig
cmayna #691431 11/03/2010 2:12 AM
back up lights
Would there have been any way to mount the switch in the freeze-plug hole instead of drilling?
