Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#689595 10/27/2010 3:15 PM
I've installed a '54 235 into my '50 3800, will there be any clearance problems between fan and radiator? Thanks in advance, Clint
Stovebolt_six #689621 10/27/2010 4:54 PM
not if it is indeed a 54.
philip t #689980 10/28/2010 9:54 PM
I just got done putting a 55-235 pass engine in my 52-3100,I got a tell You that the water pump adaptor to use the 216 water pump on the 235 engine worked out great it puts the water pump at the right place in the center of the rad. an you can use a standard 216 water pump and upper and lower rad. hoses and the engine never has gone above 180 deg.I got mine from Jim Carter's.
Pete
Pete52 #690071 10/29/2010 3:10 AM
You don't need the water pump adapter plate on the 1954-1955 1st series 235-261 engines.
Clint,your 1954 235 will fit like a glove.
Tim
1951 3100 Chevrolet
