1 members (klhansen),
46
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I have an older AD truck, but I like Jim Carter. http://www.oldchevytrucks.biz/55_66/t1.aspI also use The Filling Station.http://www.fillingstation.com/ Nice looking mater. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Oct 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 32 | From spanky on a different post:
6700?, Donnoman your truck looks to be a 6100, or 6400. 6700 series is a Schoolbus chassis. If "6700" is what your fender emblems say, they have been switched.
In the one vin calc I ran it in it said it was a 6100; So I suspect you are right. Searching for 6700 all I got were schoolbusses.
Taking a closer look at the truck; Neither fender fits very well so I think I can assume they came from something else. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | donnoman, Your serial number confirms it's a 6100 (130" wheel base and a 60" CA). 6A57O102417 breaks down as follows; 6A = 6100 Series 57 = year O = Oakland Plant 102417 = unit number starting with 100001 (you have the 2,417th 6A out of Oakland). Welcome to the Stovebolt! Mike B  | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Very nice truck I really like it and the big window cab is rare very rare in the big trucks. I will have to check and see I may have a set of 57 6199 emblems that I would be willing to part with. My truck is a 56 6100 and it has its correct emblems.
| | | | | Joined: Oct 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 32 | Send me an email if you have those emblems. [email protected] I want to try and identify the manufacturer of the wrecker boom setup. I'll get some closer pictures tomorrow or so. If you recognize it let me know, or know of some pics with a truck with a similar setup.
| | | | | Joined: Oct 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 32 | @Mike, what is the 60" CA ?
And is the 130" wheel base measured from center of front wheel to center of rear?
@HeavyHauler if my big window cab is rare; what was the more typical arrangement? Ahh I took a look at your truck I see now.
Perhaps because mine was to be a wrecker they wanted better visibility; or they just got lucky.
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | CA stands for Cab to Axel. Measured from the back of the Cab to the center of the rear Axel.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | I have a 4400 with a slop bed on the back http://www.flickr.com/photos/55chevytruck/5053727013/if you need any measurements checked for a comparison i am happy to assist. Mine is a 4 spd manual 396 BBC - with a watson 2 spd underdrive - just getting it road ready now - had a little drive on Sat, and it is brilliant ! Does yours have shock absorbers ( Dampers) ? Enjoy - it is a nice old truck I do love a big recovery. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | donnoman, My tow truck has the big window also...they're not that rare, but they are desirable. Take a look through the Gallery pictures for 55-59 and you'll see quite a few. Mike B  | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Well Mike out of more than 59 big bolts in the gallery you and Tom Petroff have the only two big window cabs and Tom put the big window cab on his. I would say big window big bolts are fairly rare.  | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Hevy, I missunderstood, the big back windows cabs are rare on the BIG Bolts, but are not rare in general as lots of small bolts have them. Road Tractors and Tow Trucks were about the only Big Bolts that had a need for the big back window. Mike B  | | |
