3 members (wilbur53, 2 invisible), 71 guests, and 3 robots.
Topics128,109
Posts1,056,572
Members48,448
' Offline
I'm near welding in the motor mounts on my 350. My floorboard is against the trans. Bellhousing. It's just touching at the top. Is that a problem? Can't get the front of the engine lower because the balancer is 1/2" from the Power Steering. Running a Fan Clutch and Fan so I wanted to get the engine as far back as possible. (I have 2 degrees neg. on the Balancer so the Differential Pinion can be set at 0 degrees) Will noise transfer into the cab with the floor touching the transmission?
Oh Ya!! You'll get a nice drumming vibration from the contact.
Either grind off the contact point on the bell or massage the firewall with a BFH.
Yes, it's a problem, and yes, noise will be transferred.
Move engine forward/down, or move floor up/back.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Yup....I raised the rear of my TH350 with a 1" spacer to zero out my carb base..Also to gain some distributor/firewall clearance....yes, mines rubbing also.I need to take a wizzwheel and do some trimming.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
You'll need to cut/hammer/grind enough clearance into the body to not only keep it from touching when it's not running, but add a little extra room to account for engine movement when under torque. Things are going to move around a little when you step on the gas- - -usually the driver's side tries to lift a little until the flex in the motor mounts gets taken up.
Mine was touching the firewall to. I took a pair of tin snips and cut the same arch as the tranny. A little at a time. When I had the clearance, like Jerry suggested, I took my dremel tool and smoothed it up real good. Once the floor covering is in it no one will ever know.
I had the same problem,I just trimmed enough (about 1/2") to gain a little clearance and as Alvin mentioned,the trans cover will 'hide' it.
More pix on Flickr.
' Offline
Well, as a final report, I had to move the engine forward because of the HEI Distributor being so close to the firewall; then I had the welding shop make a 3/4" thick plate which was welded over the transmission mounting surface (that raised the rear of the transmission); then I found, with the whole thing forward abit, I now have about 1/4" clearance from the bellhousing. I'll follow your suggestions and trim about 1/2" total. I did think there was a possibility of noise in the cab with the floorboard touching the transmission and you guys reconfirmed that. I'm installing a lot of sound deadening material in the cab prior to upholstery so what happens here is important. Again, thanks.
~Jim
