9 members (Peggy M, Otto Skorzeny, tclederman, Shade Baby, DadsFirstPickup, FAST55, Bucker, wilbur53, 1 invisible),
78
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | Hello all, I just recently bought a 38 Chevy truck and need some info. The hood was just sitting on the truck when I bought it. The truck had no grill and was missing something else on top of the grill shell. I have been trying to find a pic or two that would show me what I am missing. It looks like there was a piece that ran across the top of the shell but it is missing.That must be where the prop rods and the front of the hood mounts but I am just guessing. I am looking for parts but don't know what I am looking for there. Anyone ? Thanks, Denny
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Some of the suppliers have illustrations which may be helpful. I have a few related diagrams that I could scan. If you want to send me a PM with an Email address, I could send them over to you.
I don't know how close the 38 car and truck were in regards to the sheet metal but on the sedan there is a central chrome piece that slides over the two hood halves and attaches at the front and the back. This forms the hinge arrangement. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The piece on top of the grill shell (sometimes called a doghouse) would be the upper baffle. I see them fairly regularly on ebay. The upper baffle for a PU is different from that of a car. On a car the hood props are at the firewall end of the hood. I've not seen a truck set up but I always assumed they were similar. This shows the upper baffle on my 38 coupe. I don't have a good pic of just the hood props but the very upper right of this pic shows the prop mount location on my coupe.
| | | | | Joined: Nov 2008 Posts: 48 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 48 | Are you just missing the Grille or the entire front cowl and radiator core support? The rear end of the butterfly hood rod slides into a bracket mounted to the upper side of the front cab cowling. The forward end of the rod slides into the back of the hood ornament on the pickups. hope that helps.
Sometimes you got to leave 'em like you found 'em.
| | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | I think I described my missing parts wrong. All I have is the grill shell minus the top baffle. When I said prop rods, I was wrong. What I should of said was I don't have nor know how the radiator support rods go. I assume they bolt to the upper baffle somehow and still not sure how the hood attaches up front. What I am calling a grill shell, I think you are calling a front cowl and radiator core support which I have.Thanks , Dennis | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | Yea, It's starting to make sense. What is the part description for the piece that the support rods hook to? Thanks again. Dennis | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Core support/doghouse/grill shell....three names I've heard it called.
| | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | Well I got my missing parts problem solved.I bought a front clip from another 37 truck. I am picking it up tomorrow.Can't wait. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Well, you have me curious. You said you have a 38 truck, but you bought a front clip from a 37 truck. That's not going to work because the whole raditor cowl and upper baffle are different on a 37 than a 38. None of those parts are interchangable. Let me know what you are going to do. I might need a few of the 37 parts myself. Thank you!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | I am changing the whole frontend, radiator cowl or dog house, hood and fenders.. From the cab back is 38, everything foward of the cab is 37. Later, Dennis | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The fenders are the same for both years. So your 38 will be a 37 when you finish.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Except for the title. There's a guy in Newkirk OK who put a 38 front clip on a 37 sedan because he couldn't find the necessary 38 sheet metal. Makes it a bit confusing at times.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Of course, there will be all of the other little things that will still make it a 38 instead of a 37. It'll be a 37.5!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | Yea, 37.5 it will be. I just like the grill on the 37 better than the 38. Either way it will be a pretty cool truck when finished. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... Joe, make that a 38 1st series. Hehehe LOL | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Very rare, rare truck! A 1938 1st Series! WOW!
