7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker), 60 guests, and 2 robots.
Topics128,022
Posts1,055,387
Members48,422
#688712 10/24/2010 12:53 AM
I am working on a 42 chevy 3/4 pickup. When I drive it down the road at about 35mph it starts to shake really bad in the front end. It is also hard to turn the right. I have greased the front end which didn't help. I did raise it up on a rack and when I move the front tires from left to right I have no problem moving them but I cannot move them back the other way however when I lower it back down and the front end off the floor everything moves very easy with the steerng wheel. Any ideas to try.
Bennie
Put the truck back on the rack.With a very large pry bar try to spread the suspension connections with it.Sounds like its in the steering linkage to me.
Good luck
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Along with checking everything in the steering I would not overlook the tires.
I had a shimmy/shake in my 95 truck and which started at 45 mph and it turned out the tires were the cause.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Thanks for your help but where do I pry on to spread the suspension connections? Is this where the ball goes in to the connections and are tightened up with a screw and then locked into place with a cotter pin. I have a manual so I will search this out.
Thanks again
Bennie
