| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I am working on a 42 chevy 3/4 pickup. When I drive it down the road at about 35mph it starts to shake really bad in the front end. It is also hard to turn the right. I have greased the front end which didn't help. I did raise it up on a rack and when I move the front tires from left to right I have no problem moving them but I cannot move them back the other way however when I lower it back down and the front end off the floor everything moves very easy with the steerng wheel. Any ideas to try.
Bennie | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Put the truck back on the rack.With a very large pry bar try to spread the suspension connections with it.Sounds like its in the steering linkage to me.
Good luck | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Along with checking everything in the steering I would not overlook the tires. I had a shimmy/shake in my 95 truck and which started at 45 mph and it turned out the tires were the cause.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks for your help but where do I pry on to spread the suspension connections? Is this where the ball goes in to the connections and are tightened up with a screw and then locked into place with a cotter pin. I have a manual so I will search this out.
Thanks again
Bennie | | |
