1 members (klhansen), 65 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
Okay, I bought new headlight wiring pigtail and the only indication of what the wires do is on the back of the plug the bulb mounts into. Drive, Pass, Ground. My wiring harness has 3 colored wires Headlight High, Low, and ground. I figured out the ground, but how can I tell which of the other wires go to which wire from the harness?
Second question... My parking lights are equipped to act as blinkers. I have 2 wires coming from the bulb assembly, one green and one black. How do I know which one is for the park light and which one for the flasher. I have wiring diagrams, but none address the aftermarket lights I had to buy.
Thanks a bunch!
aNDY
Power the lights up, one at a time, the brighter one will be for the turn.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
I'm still in the early stages of the wiring process and don't have a lot of stuff hooked up. Is there a way to test that without having everything hooked up? I've also considered making them all male-female connections for when I do get it all hooked up I can just switch em if they are wrong.
You can use a battery and a jumper wire, jumper to ground and light body, wires from bulb to positive.
1953 Chevy Two-Ton
I appreciate the info!
