1 members (baldeagle), 56 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#68808 11/18/2006 10:34 PM
Mycurrent little truck . 1981 short bed step side has a 305 th400 with a Doug/nash overdrive. Can the th400 be mounted to the 230,250,292 engines? Thanks again guys. I gotta ask these things being new to inliners.
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
#68809 11/18/2006 10:43 PM
Yes, they have the same bellhousing bolt pattern as the small block.
Welcome to the 'Bolt,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#68810 11/18/2006 10:45 PM
Riding in the Passing Lane
Yes, it fit right up to the engines but I understand it,s a power robbing tranny. I would not use it on smaller than the 292. It is longer & uses a different drive shaft yoke so you would have to have the driveshaft modified.
1972 Chevy c10 Cheyenne Super
#68811 11/18/2006 10:49 PM
The Chevy one will work, the BOP (Buick, Olds, Pontiac and Cadillac) can be made to work. They do use a more than twice the power a Turbo 350 uses.
The trick setup on a torque monster like a 292 might be a Powerglide. Very low power requirement and the motor would easily make it accelerate hard.
#68812 11/19/2006 2:45 AM
Z
Z Offline
i would use a 700r4 and sell the doug nash overdrive to someone with a bigblock.its worth 1000$ min.
#68813 11/19/2006 2:58 AM
Yes the Doug nash is expensive. I paid $900.00 for it and it was a good deal That is why i was considering the 770r4 as a replacement. I have used the 700r4 behind sbc in the past with great results. They must be adjusted at wot. I am considering pulling the 305 (IN GOOD SHAPE) and replacing it with a 250 (after i rebuild it) and the 700r4 trans. I could then sell the 305 and Doug/Nash overdrive to cover my cost. I`m just thinkin out loud guys Thanks for the input. Have a fun day tomorrow.
