| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68808 11/18/2006 10:34 PM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Mycurrent little truck . 1981 short bed step side has a 305 th400 with a Doug/nash overdrive. Can the th400 be mounted to the 230,250,292 engines? Thanks again guys. I gotta ask these things being new to inliners.
Jesus is Love! Never forget the Veteran. AND God bless Amercia!
#68809 11/18/2006 10:43 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Yes, they have the same bellhousing bolt pattern as the small block. Welcome to the 'Bolt, Scott | | |
#68810 11/18/2006 10:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes, it fit right up to the engines but I understand it,s a power robbing tranny. I would not use it on smaller than the 292. It is longer & uses a different drive shaft yoke so you would have to have the driveshaft modified. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#68811 11/18/2006 10:49 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The Chevy one will work, the BOP (Buick, Olds, Pontiac and Cadillac) can be made to work. They do use a more than twice the power a Turbo 350 uses.
The trick setup on a torque monster like a 292 might be a Powerglide. Very low power requirement and the motor would easily make it accelerate hard.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#68812 11/19/2006 2:45 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i would use a 700r4 and sell the doug nash overdrive to someone with a bigblock.its worth 1000$ min. | | |
#68813 11/19/2006 2:58 AM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Yes the Doug nash is expensive. I paid $900.00 for it and it was a good deal That is why i was considering the 770r4 as a replacement. I have used the 700r4 behind sbc in the past with great results. They must be adjusted at wot. I am considering pulling the 305 (IN GOOD SHAPE) and replacing it with a 250 (after i rebuild it) and the 700r4 trans. I could then sell the 305 and Doug/Nash overdrive to cover my cost. I`m just thinkin out loud guys Thanks for the input. Have a fun day tomorrow.
